Old 06-16-2011, 01:47 AM
Metallicus Metallicus is offline
Default Guitar Noise?
Right from the first moment I picked up an electric guitar, I got this trouble.
The guitar produce massive noise, which can be temporarily removed by touching the bridge/strings. I find it quite annoying, because it just doesn't fit my style to hold on the neck all the time.
I have seen quite a few people fixed this problem on some stratocaster-like guitars by soldering a copper cord from the bridge to a part inside the guitar, but I have a Les-Paul like guitar, which the bridge is fixed, and there is no way through the body so that I can solder it with the parts inside. So I decided to solder them out and decorate it.
But I am not sure which part I will solder them. So please answer these question if you can:
- Is my plan possible? How much % of success rate?
- If it is, which part should I solder it?
- Should I use copper cord? If not, which material of cord should I use?
- Does soldering like that makes the guitar any way worse?
Thanks for taking time.
Also, it doesn't just happen with distortion effect, it also affect the clean sound as well.
And it's certainly not because the cables. I double checked them and even bought a new one.
Old 06-16-2011, 01:52 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Guitar Noise?
why not use a gate or a volume pedal? Or are you talking about another kind of buzz
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-16-2011, 02:49 AM
I do have a guitar noise gate. But the point is that the buzz sound appears even when I hitting the notes.
That's the main reason. It's so frustrated when the guitar keeps buzzing when I try to do some clean melodies.
Old 06-16-2011, 06:10 AM
drokken2 drokken2 is offline
Yup that is definitely a grounding issue.
Take off your bridge and remove the saddle the bridge screws into [the one nearest to the volume and tone pots] (you can stick needle noise inside, spread the needle noise to grip and then pull)
once the saddle or bolt (whatever you want to call it) is out, take a long medium-small drill bit and drill towards your electronics cavity
then take a piece of wire (coated) and run it through
strip off both ends and solder the end in the electronics cavity to one of you pre-existing ground solder joints (on the back of you volume or tone pot)
on the bridge end, pull the wire back to where only the exposed striped wire is showing, now take a small screw driver and push the bare wire down so that the saddle/bolt can slide back into place and that when the saddle is back into its normal position, it will crush the wire under it, keeping the wires snug up against it and keeping the wire from sliding back into the hole that was drilled.
if all of you other electronics are grounded and soldered to each other then your problem will be solved
{no need to solder the wire to the bridge, just let pressure do the work for you}
ground wire install shouldn't take more than an hour if you got the right tools, i would recommend a 22 gauge wire, stranded (keep it small)
good luck :)
Old 06-16-2011, 11:02 PM
Benoni's Avatar
You can always take it into a local guitar shop and have a tech fix it up right for you.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-17-2011, 12:29 PM
moff moff is offline
Yes it's a grounding problem, but if the buzz goes away when you touch the bridge\strings, it's already grounded to that point; in fact, the strings and bridge are the only thing that IS providing a ground (through you). So, there's no need to pull your bridge off and drill. You can do it if you want, but it won't help.
Open the control cavity (where all the knobs are), and check for ground issues there. The back of each pot should be connected electrically, most commonly with a "ground bus" wire attached to the back of each pot, and then attached to the negative/ground connector on the output jack. Also, check the wiring to the pickup selector switch. There will be a "hot" from each pickup\volume pot, a common "hot" that goes to the jack, and a braided wire that is a shield. That shield should be grounded inside the control cavity as well.
Old 06-17-2011, 02:09 PM
madgt621 madgt621 is offline
Location: Current: Ikebukuro, Tokyo, Hails from: San Francisco
the real question is if the power outlets he's plugged into even goes to ground. I'm not even gonna pretend to know the electricity situation in Hanoi.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 06-17-2011, 09:08 PM
The building power doesn't matter in this case. Generally speaking, the "electrical ground" and the "audio ground" are separate. Yes, the guitar signal is an electrical circuit, but that's not what I mean...
For example, you can still use a amp in North America with a 2-prong plug, and it won't affect the guitar signal (much). There can be a buzz, but it's usually recified by pulling the plug and turning it around. The advantage of the three-prong electrical outlet is safety, in case there is a surge or short. It has no bearing on the guitar signal.
Noise from 11R guitar input conqueror Eleven Rack 3 08-28-2012 01:11 AM
Guitar String Noise mcogan Tips & Tricks 9 02-16-2006 12:28 PM
Guitar String Noise mcogan Tips & Tricks 5 01-12-2006 11:26 AM
Acoustic Guitar Noise filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 11-10-2005 10:56 PM
Need help reducing guitar amp noise michaelmouse Tips & Tricks 7 03-19-2005 11:44 AM
