Old 05-01-2010, 12:24 AM
Jeff W. Jeff W. is offline
Default Mbox Micro Audio output problems
I have an MBox2 Micro that outputs audio on both Left and Right sides, but it is a sum of only the Right audio. If I pan a signal full Right in Pro Tools the audio gets louder in both ears (about 3dB) and when panned full Left the audio goes away in both ears.
I saved the session and plugged my friends Mbox2 Micro in, reopened the session, and the audio panned to both sides as it should. After saving and returning to my MBox2 Micro, the audio did the same thing. I am using PT 8.0.3 on a Windows 7 machine.
Unless there is a firmware update that I am unaware of it appears I have a bad Mbox, can anyone help me out.
Old 05-01-2010, 09:21 AM
Default Re: Mbox Micro Audio output problems
Have you double-checked your plug and connections? Just wondering if you got a mono plug by mistake(from the Mbox output)?
Old 05-02-2010, 07:38 AM
I was running into a pair of Sensaphonics IEMs. The same exact pair of ears were used when I switched to my friends Mbox Micro and it worked flawlessly.
Old 05-02-2010, 08:48 AM
Ouch, sounds like a bad Micro to me Was your friend's Micro hooked up to your computer or his/hers? Have you checked the IO setup?
Old 05-02-2010, 10:16 AM
sunburst79 sunburst79 is offline
I would try reseting all the I/O paths in the prefs and relaunching PT. If that doesn't work try deleting the prefs and rebooting.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-03-2010, 03:12 AM
Yes, my friends Mbox Micro was plugged into my computer, using the exact same session (and it worked correctly with his). All of the I/O routing had been reset to Default while the Mbox Micro was plugged into the computer.
I figured it was a bad Micro, but just wanted to make sure no firmware update had been released for it. Thanks.
PT9 No mbox micro output on my Laptop TommyT macOS 0 03-19-2011 07:21 AM
MBox Micro vs onboard audio. sunburst79 General Discussion 3 12-06-2010 02:02 PM
problems using mbox micro iMartin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2010 05:22 AM
MBox2 Micro as Audio Output? IVIrStubbs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-15-2009 08:59 PM
Problems with Mbox 2 Micro seangp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-21-2008 12:16 PM
