Digi Pre & Midi
I keep getting the message PT can't communicate with Pre input on channel xx,
I reloaded everything, changed midi cables , reset , etc. a\Any help would be appreciated. |
Re: Digi Pre & Midi
A little info would help
Help us help you - what you need to know before posting! Windows XP and Pro Tools Setup and General Troubleshooting
Re: Digi Pre & Midi
Hi Delver ,
Before all,be sure to see the midi i/o and PRE in : application -utility -Audio Midi configuration and that they are connected right. If yes, in pro tools try to go in : Setup-Peripherals-Mic Preamps - and where is the PRE set the type on none. Chose ok and quit pro tools. Reopen pro tools and go again in : Setup-Peripherals-Mic Preamps - and now chese PRE, recevie from PRE-1 , Send to PRE-1 and OK. Now it would be ok. If you have still problem try to reset the MIDI i/o and do again the procedure. |
Audio MIDI setup says DIGI 002 midi device is offline | oliarnalds | MIDI | 17 | 10-23-2016 10:13 PM |
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup | xxicjoy | MIDI | 69 | 08-02-2013 08:40 PM |
Digi MIDI drivers cause Reason 6 'Failed to open MIDI support library' | davegibbon | Pro Tools 9 | 1 | 05-16-2012 04:08 AM |
Three MIDI ports on DIGI 002R within MIDI studio Setup | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2010 04:57 PM |
Digi, When Protools creates MIDI regions after recording MIDI info.... | Mt.Everest | Pro Tools TDM Systems (Mac) | 0 | 07-21-2001 12:12 AM |
