Old 09-24-2009, 06:40 AM
Tank Tank is offline
Default change the pan law
There's a way to change the pan law at -4.5db ?
Old 09-24-2009, 11:41 AM
Craig F Craig F is offline
Default Re: change the pan law
no
Thank you,
Craig
Old 09-24-2009, 01:48 PM
Why pro tools HD don't have this option?? I think it would be chose in some preferences.... like others software have.
Digi, it's a problem introduce a preference for the panning law ?
At the moment i'm using it at -3db and I find it good,but I think that -4.5 it would be better for me.
Old 10-24-2009, 06:36 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
If you changed it to -4.5 then, when your mixes are listened to as a MONO PROGRAM (AM radio or MONO MP3), your center channel stuff will be too soft.
Don't mess with the math!!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 10-24-2009, 11:22 PM
JFreak's Avatar
JFreak JFreak is online now
There are two options: stereo mixer uses -3.0 pan law and surround mixer uses -2.5 (I use the latter)
Janne
Old 10-25-2009, 08:51 AM
Pete Gates Pete Gates is offline
Other way round isn't it?
Pete
Old 10-25-2009, 10:50 AM
JFreak's Avatar
Pete
Come to think of it, yes, I stand corrected
Janne
Old 02-01-2010, 10:36 AM
Yes,surround mixer set the pan law at -3.
I asked if it could be changed becouse on cubase and logic you can chose the pan law.
Eric ... what math you talking about? if I mix with the pan law at -4,5 I take care of my center section, so in my final stereo file it will be ok. If you listen in mono it would be ok.
Change the pan law cange the way of mixing , not the way of listen the final mix on radio.
Old 06-15-2010, 10:37 PM
pristineb pristineb is offline
How do I switch between stereo (2.5db) and surround (3db?)
Any help?
Old 06-16-2010, 03:26 AM
Stig Eliassen's Avatar
Just to explain again how to change the mixer to dithered or surround dithered!
Close pro tools
go to the digidesign folder situated in system drive/library/app support/digidesign
in this digidesign folder you'll find the "plugins" folder and the "un-used plugins" folder.
take the stereomixer.dpm plugin from the "plugins" folder and place it in the "un-used plugs" folder
Take the stereodithered or the surround dithered mixer (if want to try the surround mixer which can still be used for normal stereo mixing!) from the "un-used plugs" folder and place it in the "plugins" folder.
Now when you reboot PT you will be using one of the dithered mixers.
Yes you can use the surround mixer for normal stereo work!
trade-off? might use a bit more Chip space!
Obviously, you don't use dithered versions unless you want to.
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Eleven Rack doesn't change sound output when I change to a new rig Jlambton Eleven Rack 4 02-28-2011 11:51 PM
Loop tracks stuck together - change 1 change all jrwallace Pro Tools M-Powered (Mac) 1 02-22-2010 09:19 PM
Tempo change without pitch change for audio layman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2002 07:14 PM
