Creating 16/44.1 audio file
I want to capture the stereo output from my analog console at 16/44.1 to compile a redbook CD. I want to use my Cranesong HEDD for A/D and send a 16/44.1 digital signal via SPDIF. Then capture the signal on my Macbook Pro in a PT11 session at 16/44.1 Sounds simple enough.
However, I am using a Tascam US-366 at my interface, i.e. SPDIF from HEDD to US-366 and USB out to the MBP. The specs for the US-366 state that it supports 16 and 24 bit but internally runs at 24 bit. Therefore, I presume that the TASCAM US-366 is taking my 16 bit signal and jacking it up to 24 bit and then Protools is truncating the 24 bit signal back down to 16 bit. Any thoughts are greatly appreciated. It maybe that I have a misconception regarding bit depth. I certainly don't want to this much trouble if my bit rate gets changed back and forth. |
Re: Creating 16/44.1 audio file
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yup, you're only adding 8-zeros to the end of the data word and they will 'fall' off when you go back to 16-bit. Actually, there's no need to dither, either.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
thanks for the input.
A few years back I did many hours of A/B ing and found that the best sounding redbook CDs came from A/D to Cranesong HEDD > 16/44.1 > to CD burner (Tascam DVRA1000). Now my workflow has changed and I want to burn my demos in a separate DAW using Wavelab. I am after the same quality but want to ditch the DVRA1000. I have been doing some comparisons and am still undecided. I want to figure this out and move on. I am just not wanting to unwittingly add garbage by going back and forth with bit depth. I wonder if I would be better off sticking with 24 bit all the way through until burning the CD. |
Yes, you should dither if you're going from an ORIGINAL 24 bit file to 16 bit. However, in the scenario you're talking about, there isn't any data in the last 8 bits. You're taking a 16 bit file, inputing into a 24 bit recorder and adding nothing, then spitting it back out to 16 bit. If you're not editing it or making any changes to the file, there isn't any reason to dither.
However, if you imported the 16 bit file into a 24 bit ProTools session and edited to made changes to it, then you would want to dither on the way out. In this case, you've added new information to the last 8 bits of the data. If you started with a 24 bit file, and edited it in ProTools (or your DVRA1K, which I have and LOVE), dithering should ALWAYS be done at the last possible moment and only ONCE. Can your Cranesong not operate at 24 bit? If nothing else, even if you're only doing a CD now, you should make your master mix the HIGHEST resolution possible. You never know what you may do with it later, i.e. high sample rate/high resolution downloads.
Eric, thanks for the thoughtful response. You clearly answered the question for me. Yes, my Cranesong will do 24bit. However, what I am trying to accomplish is to make quick demos that sound good. Turns out that the Cranesong at 16/44.1 sounds better than most converters at 24/88.1 I would take my 16/44.1 from the Cranesong and feed it to the DVRA1000 to print a redbook CD and I was totally happy with the result. For higher resolution 88.1 or 96, I just bounce to open tracks in the PT session.
I recently picked up Wavelab 8 and have it on a second DAW. I have been feeding my final audio from PT out D/A and into analog EQ and Dynamics into the Cranesong and printing into Wavelab 8. I was erroneously thinking that I should print 16 bit Wavelab; thus, avoiding dither. However, I am making adjustments in Wavelab 8, so I am just going to print to Wavelab8 at 24 bit and dither as I convert to 16 bit on the way to my final CD print. |
Creating a multichannel BWAV file | colinato | Post - Surround - Video | 11 | 10-24-2014 03:32 PM |
ProTools keeps damaging/corupting creating a missing file | Pro Logic | Pro Tools 9 | 12 | 08-04-2013 08:23 AM |
8.4 Creating Audio File Folder on another drive | hmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-11-2010 01:32 PM |
creating .mov/mpeg4 file from dvd - other ways? | 1tonstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-09-2006 10:08 AM |
Program Error when creating new file | moosh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2001 01:23 PM |
