spdif out on audigy to spdif in on mbox?
is it possible to play mp3s on the audigy send the signal thru spdif out to the mbox spdif in to play on the monitor outputs of the mbox? I'm just trying to be able to play mp3s well using other programs without it stopping like the wavedriver does.
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2 OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs NEW Dverb 1024 - 283 64 - 235 |
Re: spdif out on audigy to spdif in on mbox?
In order to use your audigy sound card you need a program ( like wmp) to play the mp3s.
Is your audigy sound card in another PC? if so Yes!
Camilo Toledo |
I'll have to try that. Theorectically that should work, no? If I'm thinking right, just select S/PDIF for the input on a stereo track within Pro Tools. You may have to hit record, but the sound from Win Amp or whatever media player you're using on your computer should stream though the PT track if the Audigy S/PDIF out is going in to the MBox S/PDIF.
I'll tell you what does work because I'm doing it, but may not be of any use to you. MBox S/PDIF out to my Audigy breakout box S/PDIF in. Light pipe out from my Audigy breakout box to the light pipe 'in' of my monitors. I do this because I do a lot of radio imaging production which involves using sound bites from various websites. This allows me to monitor my PT mix AND listen to wav and mp3 files through Windows Media Player that I may want to use in a production without having to use the wave driver. Pretty much, my MBox digital output and Audigy output are fed to the monitors simultaniously allowing me to listen to either source. But to do that, your monitors have to have a light pipe 'in'. |
Yeah, I guess the only reason it's working for me because I'm routing my main pair of monitors out of the Audigy light pipe. My anolog monitors that are coming out of the MBox2 monitor outs aren't reciving the Windows Media Player audio of course.
anyone know why it works one way but not the other? the spdif out on the mbox works and lets me listen to a protools session via the headphone jack on the audigy why doesnt the in let me send mp3 audio from the audigy to my monitors thru the mbox?
1) does that MP3 audio show up on the audigy's headphone/analog out ?
2) try connecting the analog out to Mbox line in..I think the SPDIF will only work in a PT session..I might be wrong, has been a while w/Mbox. good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? | cueball73 | macOS | 0 | 05-22-2012 12:41 PM |
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) | chrisdee | Pro Tools HDX & HD Native Systems (Mac) | 9 | 04-02-2012 05:10 AM |
Spdif RCA to Spdif Optical conversion - degradation?? | Hollow Body | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2011 08:21 AM |
Digi 96io - can you mix Optical SPDIF and phono SPDIF? | buckaroo | Pro Tools TDM Systems (Mac) | 1 | 08-24-2009 11:20 AM |
Echo Mia W/ SPDIF also does RCA style SPDIF cause the same crashes as optical?? | Paul_m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-16-2003 05:41 AM |
