New To Pro Tools, I Need Advice Before Installing
So here's the deal. I bought a brand new Eleven Rack with Pro Tools 10 with a Free upgrade to Pro Tools 11. My main interest is the Eleven Rack, but I like the idea of the graphic interface for the 11R in Pro Tools and maybe trying a little very light and easy recording. I'm sure Pro Tools 10/11 are way overkill for me. To be honest, I'm afraid my laptop may not be enough to load and run Pro Tools. My laptop is a PC based Asus with Intel Core i3, 2.30 GHz CPU with 6GB Memory running Windows 7. I was told I needed at least Pro Tools 9 to run with Windows 7. Is my laptop going to be a problem?
So, I was thinking I could sell the Pro Tools 10/11 that came with my Eleven Rack and buy Pro Tools 9. Is this a bad idea? Would the cost difference between Pro Tools 9 and Pro Tools 10/11 be enough to make it worth while? If so, is there a certain Pro Tools 9 I would need? Would I need to make sure I buy an unused copy of Pro Tools 9 with unused iLok? Or will a used copy of Pro Tools 9 work fine. I've heard some bad things about transfers of Pro Tools and iLoks. So, before I do anything with the Eleven Rack and Pro Tools (haven't even opened the box yet), I need to decide what I'm going to do about Pro Tools. Any help and advice is greatly appreciated. I'm anxious to get going on this. |
Re: New To Pro Tools, I Need Advice Before Installing
You can post a Sandra Report here and someone on the DUC can point out any potential issues, FYI a second hardrive would be necessary to record audio.
It would be difficult to find a new, unregistered version of Pro Tools 9. Whether or not to keep 10/11 or find a used copy with an included ilok key is your choice, my advice is look for a copy that an owner can transfer to you, the only requirement is you would need an ilok and ilok account, the average rate for one is $185 give or take (on a good day :) ) You can sell the bundle for..... well you decide
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
I found out that Pro Tools 8.0.4 will work with Windows 7. I can buy a legal copy for $59. I can then sell my new unregistered Pro Tools 10 with free upgrade to Pro Tools 11 and my new unregistered iLok. I'm not sure what the Pro Tools 10/11 with iLok should sell for. Any idea on what to ask? Here's the Pro Tools 8.0.4 I can buy. Can you see any reason this would not work?
http://www.ebay.com/itm/Avid-PRO-TOO...item19de26d4f6 |
Why tie a dead piece of software around your neck?
Any 11r updates will probably require 11 (maybe 10) it install (unless a freestanding editor come out)
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
The trick is you need secondary audio drive- external is fine Keep ProTools 11 it will even run better on your laptop I just got my little orange box also - that thing rocks
I bought my iLok for $50 online at the iLok website. Came in the mail
http://protoolstutorial.org/ |
Installing PT's 9.x on OSX 10.7.1 Advice Sought! | TheSteve | macOS | 9 | 09-06-2011 05:28 PM |
Advice for installing PT 9 crossgrade? | RobRaden | Pro Tools 9 | 5 | 01-26-2011 03:58 PM |
Need advice on installing PTLE on a macPro | Tom Swift | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-01-2007 03:00 AM |
Advice on installing PT 7.3 | gpgiusti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-16-2007 06:35 PM |
Any Advice on installing 2nd ATA Drive? | skoehler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-22-2001 07:26 PM |
