Old 03-28-2017, 12:24 PM
Andy Gone's Avatar
Andy Gone Andy Gone is offline
Default Re: Aphex Vintage Aural Exciter
Thank you people, interesting ideas.
Using Aphex Vintage Aural Exciter for vocals in the project I am mixing now. Just as an insert, to make vox more lively. In my case, what worked for me is DAW HPF -> Waves Vocal Rider -> CLA-2A -> CLA-76 -> Aural Exciter -> DAW EQ -> Waves H-delay. I like this chain.
Old 04-02-2017, 05:22 PM
Actually, I'm a fan of doing Subtractive EQ -> Enhancer/Harmonics -> Compression -> Additive EQ
I like to remove some of the "nasties", enhance the desirable, compress it to bring out out a bit more and boost a little to taste. Depending what the mix needs.
Not just with the Aphex, which is a great unit by the way, but with anything I use to generate harmonics in general. It's good to have several enhancers doing different things in my opinion the mix is less likely to sound "hyped" and harsh in some instances.
Old 04-03-2017, 02:16 AM
Andy Gone's Avatar
Way to do too, it depends if you want to compress it with harmonics or not.
Old 06-02-2017, 07:18 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Also great as a squasher on a parallel processed drum group. Smash and add to taste.
Aphex aphex big bottom pro/aural exciter bundle tdm rtas Tank Buy & Sell 0 06-10-2013 05:45 AM
Waves Aphex Vintage Aural Exciter® plugin bacchus40 Pro Tools 10 4 08-01-2012 07:02 PM
Q : Aphex Aural Exciter TDM Aquarius Pro Tools TDM Systems (Mac) 4 03-17-2008 10:12 AM
Aphex aural exciter Ricco Tips & Tricks 4 09-02-2000 12:02 AM
Aphex Aural Exciter AdamFrick Pro Tools TDM Systems (Mac) 1 11-12-1999 01:36 PM
