#221
Re: Dark Theme in Pro Tools 2020.11
Ok, I just opened dark mode. I wondered why Avid never developed the visual interface for Pro Tools. Now I understand ! How awful. Please don't touch anything!
(We had to go in nuances, with subdued lighting effects, darker parts, but not to go into a cave with a bulldozer! How to spoil the most beautiful interface among DAWs ?: exactly like that!)
#222
Re: Worst Dark Mode Ever
My best guess to this is that they are RGBA values; with the fourth (A)lpha adjusting the transparency/opacity of the color. 65535 is the max value of certain data types in C, so I would guess they are just converting to an RGB range (0 to 255). You can get the RGB value by just taking the number from the file and dividing by 256. So 65535 / 256 = 255, which is the max RGB value. |
#223
I used your old salmon numbers and its now just white/grey: cMacWindowTitleBar (46147,15278,12850) cMacWindowTitleBarFloater (12566, 32609,11883) does it need another value? also I didnt save the old original values.... thought I did. but nope. I want your tweaks anyways. thanks! Last edited by arche3; 11-20-2020 at 11:51 AM. |
#224
cMacWindowTitleBar (46147,15278,12850, 65535) cMacWindowTitleBarFloater (12566, 32609,11883, 65535) |
#225
Sent from my SM-G986U using Tapatalk |
#226
a member on kvr (that I psoted about before) posted a tutorial on how to edit the actual interface, I think I will experiment after work, apparently works for dark mode too:
https://www.youtube.com/watch?v=fBPzGtgMbbg |
#227
cMacWindowTitleBar 12566,32609,11883,65535 cMacWindowTitleBarFloater 7125,15297,53000,65535 The colors you posted are my original color numbers; sorry I don't have a screenshot for that. If someone has a way to host the screengrab so it can be better seen than using the paperclip on a forum post let me know and I'll email you the grab so it can be seen better to get the full breadth of what I did. |
#228
#229
Glad it's working for you. It's just a shame I could only put up a small version of the screengrab. If you call up the OSX ColorSync utility and set it for 16 bit in the bottom left chooser you can experiment with the sliders to get different colors. That's how I came up with mine.
#230
I use https://imgbb.com but there’s loads to choose from. Sent from my iPhone using Tapatalk |
"Dark" theme improvements in 2021.3 | midnightrambler | Pro Tools | 19 | 04-04-2021 05:15 AM |
How to change Pro Tools 12 to a Dark theme/skin | Defier | Pro Tools 12 | 7 | 03-26-2016 05:22 PM |
Pro Tools 8 theme for Reaper? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-09-2010 07:51 AM |
Pro tools theme song....! | roijin | Pro Tools TDM Systems (Mac) | 2 | 11-27-2001 07:15 AM |
