Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 07-11-2019, 06:08 AM
qtvaudio qtvaudio is offline
Default S5 Graphics not working after installing new RAID
Hey S5 forum
On advisement, I was trying to install new hard drives and OS on our SC264. I had just installed and striped a pair of HDs as a RAID1 mirror set but on reboot am confronted with a blank screen.
I had removed the previous, functional HDs as a precaution and so have now reinstalled them but the problem is the same; I'm not seeing any startup screens, DEL is not launching the BIOS settings programme; in short I have lost all graphics and the SC264 is not booting.
Any advice as to what the problem could be?
Thanks
R
Old 07-11-2019, 09:18 AM
Default Re: S5 Graphics not working after installing new RAID
To elaborate;
SC264 is not even entering POST as far as I can tell; certainly not outputting any video to the onboard VGA. I have tried resetting CMOS by removing the battery for 15 minutes; No Luck.
Now here's the weird thing; looking at the manual for the motherboard, there's a Reset CMOS jumper (as normal) but when I try to use this, the computer won't power on at all! So, when the CMOS Rest jumper is in normal operation mode (ie Pins 2+3=No Reset) there's power, but if I close the reset circuit (Pins 1+2=Reset) there's no power, the PCUs dont start.
Any clues?
R
Old 07-12-2019, 10:13 AM
One of the RAM modules had failed; removing it let me POST and check everything through. RAID had degraded so it's repairing itself as we speak :)
Waves 7 isn't working after installing iTunes 10 - FIXED! psycho_monkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 28 09-15-2010 09:41 AM
Mbox 2 not working after installing HD. jjmoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-18-2009 12:09 AM
RAID or MAC OS Extended when working with final cut and pro-tools?? 1ace1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-23-2008 04:57 AM
Installing Not Working Gonkboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-02-2008 06:47 PM
When is a RAID really a RAID? Will this increase track count? ThomCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-25-2000 12:28 AM
