Old 01-07-2008, 12:14 PM
MASTERLINKSTUDIOS MASTERLINKSTUDIOS is offline
Default CAN I HEAR RECORDED TRACK AND PERSON THAT WILL PUNCH IN
I THOUGHT IT WAS A LIMITATION IN LE. I RECENTLY UPGRADED TO HD2,C24 AND AM WONDERING IF THERE IS A WAY THAT I CAN HEAR A VOCAL PERFORMANCE THATS ALREADY RECORDED AND HAVE THAT SAME TRACK ENABLED TO QUICK PUNCH RECORD AND ALSO HEAR THE PERSON SINGING AT THE SAME TIME SO I HEAR THEM BOTH AT SAME TIME TO BE BETTER ABLE TO PUNCH IN AT PRECISE POINT THAT BOTH VOCALS ARE MATCHING ,WORD FOR WORD,THANKS FOR ANY HELP AND I HOPE THIS ISNT A QUESTION THATS BEEN ANSWERED BEFORE BECAUSE I NEVER SAW THE POST
Macpro 2.88-4 Gig Ram,HD2,Big Ben,Rosetta 200,Dangerous D Box,Mercury Bundle + Studio classics bundle ,C/24,2-UA 6176,U87ai,Genelec 8050 & 8020,Logic,Final Cut Studio 2,Canon hxa1(hd camera)-Macbook Pro,Mbox 2 Micro.http://www.masterlinkstudios.com/.http://www.myspace.com/masterlinkstudios
Old 01-07-2008, 01:04 PM
Keith Moore Keith Moore is offline
Default Re: CAN I HEAR RECORDED TRACK AND PERSON THAT WILL PUNCH IN
I'm pretty sure you can't. Would be a nice feature though. You could always bounce between 2 audio tracks and edit together later.
Pro Tools HDX 2021.6.0
Lynx Aurora 16
Ross Martin PCM4222
Ross Martin Super Beast
Apple Mac Pro 8 Core 2.66Ghz 16GB RAM
OSX 10.14.6
http://www.keith-moore.org
Old 01-07-2008, 01:19 PM
Drew Mazurek's Avatar
ahh, who remembers the SSL Super Cue™ system on 4K desks? It did just what you want. Who says we always progress!!!
www.drewmazurek.com
Old 01-07-2008, 01:56 PM
WHEN I HAD MY DIGITAL 8 BUS AND MACKIE HDR 2496 I WAS ALBE TO HEAR BOTH.WE GOTTA GIVE UP SOME THINGS TO GAIN OTHERS I GUESS??????????????
Old 01-07-2008, 02:06 PM
WildHoney WildHoney is offline
I workaround it by setting up a dummy track that's just in input monitor mode in addition to the regular track to which I'm recording. Also allows you to hear the singer talking to you during playback or any other time without having to be worrying about switching off record enable or input monitor.
Old 01-07-2008, 02:08 PM
crizdee's Avatar
crizdee crizdee is offline
Yes you can up till you punch in!!, and you can also turn your caps-lock off
Have the track in record mode "and" input monitor, you'll hear whats recorded and the artist till you punch in then you'll hear the new recording.
You want to hear both whilst recording? you'll have to drag region to a new track and cut and mute the track where you want to drop.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-07-2008, 02:45 PM
Jonathan Starr Jonathan Starr is offline
Nice tip, Thanks.
Can't believe I never tried to enable record and input simultaneously.
Aloha,
Jonathan
Chris
[/QUOTE]
Old 01-07-2008, 04:27 PM
studiojimi's Avatar
studiojimi studiojimi is offline
this was obviously a CAPITAL OFFENSE
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 01-07-2008, 06:03 PM
sorry about my caps being on guys,i dont type well and forgot they were on.sorry again.has anyone tried what the gentleman suggested and record with the input on and if so does it work.thanks for the help everyone
Old 01-07-2008, 09:59 PM
zakco zakco is offline
This is my #1 complaint with PT.
After years of working with other DAWs, I became very used to being able to hear playback AND input monitoring for a given track simultaneously. It is a HUGE workflow advantage for many reasons:
1. It helps the talent get in the pocket during punch-ins. They are able to lock in with their previous performance that much easier when they can hear themselves during pre-roll.
2. This in turn, helps the engineer know when the performance is really locked in and and as result, know when to punch.
3. Communicating with the talent. I don't know how many times I've hit playback and the talent is trying to get my attention and I'm oblivious because I can't f'n hear them...ugh.
If you've never worked this way then you don't know what your missing. Once you've gotten used to that functionality it's really hard to accept working without it. You should see the look on my clients faces when I explain to them that my new $30k fancy-dancey PTHD rig can't do this after they've gotten used to my old native system.
Every other major hardware manufacture that I can think of provides some form of latency free monitor mixer that will pass audio via direct monitoring completely independently of the DAW it is fronting. Sure you can't use plugins on input-monitored tracks, but for those of us with consoles and outboard, this is really a non-issue. This is by far my preferred way to work.
Don't get me wrong, I love PTHD and it has many advantages over a native system (obviously), but I actually miss my native rig while tracking. I would LOVE to see digi implement some kind of "always on" direct monitoring scheme.
-Z-
Quick punch.... can't hear track audio until I punch in stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-31-2017 02:11 AM
pro tools 10 i cant hear my recording/recorded track cassie11 Windows 7 11-28-2012 05:53 PM
How do you punch in and still hear the track? Ihatecomputers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-02-2011 02:22 PM
Can not hear the recorded track klrss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-12-2007 09:04 AM
Can't hear myself prior to the punch JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2002 06:30 AM
