Increasing usb output volume?
I'm using cakewalk or reaper for recording using the USB outputs. Is there a way to increase the output volume of the usb output? It ends up tracking way too low in cakewalk or reaper.
Re: Increasing usb output volume?
You mean for the rig to reaper? When you hold the edit menu on the 11r for 2 sec. there are several option available; one of them is rig balancing; you can adjust the overall volume for every preset in that menu.
it's already set to 0.0 there. You can't go any higher. Surely there's a way to increase the overall output through the USB IO channel?
What's the output of your guitar like? On the low side? Try getting a hotter level there (which I think is really your problem - low source into the 11R). Maybe you have a low level set somewheres in the 11R patch(es) you're using. If your axe has active pickups put in a new battery. |
Really - how low IS the signal from the 11r? Can't it match the other tracks you have in Sonar? Try lowering the other tracks and see if you can't get it to work. And are you absolutely sure you don't have a mistake in your gain staging in the 11r and dropping the level someplace? If not, you may well have a defective 11r. Nobody else seems to have a problem with this. You might well just have to go with a separate analog output from the 11r to your daw's sound I/O. Nothing worng with that.
I'm not absolutely sure I don't have a problem dropping the gain somewhere else but the gain is very good coming out of the analog outputs. It's just tapping off the asio driver where it seems to be low. |
I could try removing and adding the driver to reaper and see if it makes a diff but I don't see a param for input level. Most other drivers give you a control panel to set the levels. |
also checked control panel and verified that output is set to 100% for the eleven rack driver. Does pro tools have a proprietary interface to the eleven to get more gain out of it?
Increasing the volume on a bounced song | gazblake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-18-2010 06:47 AM |
Increasing volume while avoiding peaking? | whateverwrks | Tips & Tricks | 8 | 10-02-2007 07:09 PM |
Increasing the volume of final mastered mix? | RML | Tips & Tricks | 4 | 12-28-2005 07:24 AM |
Firewire, G4 locking up, increasing volume | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-01-2003 02:18 PM |
Increasing post recording volume level | Raymond Hardy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-09-2003 11:17 AM |
