Old 06-24-2013, 05:11 PM
acelo acelo is offline
Default Protools 10.3.6 crash (organize Plug-In menu)
Hey guys. I have a little dilemma. I'm running the Pro Tools HD 10.3.6 software with an Avid Mbox Pro as the interface. I've been running this setup flawlessly on OSX 10.6.8 since Pro Tools 9. Earlier this week I updated to 10.3.6 & I also updated the Mbox Pro software to 1.2.0. This morning I installed freeware from off the Klanghelm site(the DC1A & IVGI). When I tried to open PT it was crashing at the "Initializing Machine Controls" on startup page. So I trashed all Prefs, uninstalled PT(Clean Uninstall) & repaired Disk Permissions. Pro Tools opened just fine after but when I went into my Preferences, went into the "Organize Plug-in Menus By" portion & selected either "Manufacture" or "Category and Manufacture" it crashes soon as I hit OK. If I selected "Flat" or just "Category" it did it just fine though. Any advice would help....Thanks.
Protools HD2 Accel PCI & HD2 Accel PCIe, Mac Pro 8 core Intel, Command 8, Apple G5 1.8 single processor, Avalon 737sp, DBX 160X, Open Labs NEKO(with four 500gb internal harddrives), Akai MPC 3000 & 2000, Emu Sp-1200, Roland XP80, Yamaha Motif Rack, all the Emu modules, Korg MS2000, HEDD 192, Mac Book dual 2.4 with 4gigs of ram, Logic Studio 8, Axiom 61 MK2, Protools LE(Mbox Mini) and lyrics and beats 4 da streets!!
Old 06-24-2013, 06:56 PM
Chief Technician's Avatar
Question Re: Protools 10.3.6 crash (organize Plug-In menu)
Does the problem recur if you remove that software you installed?
Old 06-25-2013, 05:10 AM
Default Re: Protools 10.3.6 crash (organize Plug-In menu)
Yes it does. But what I found weird is that I removed the Nomad Factory bundle that I installed the other day and it seems fine...I will have to boot it up again today. Can it be Pro Tools can only Categorize so many Plug ins at a time?
Old 06-25-2013, 11:01 AM
Exclamation Re: Protools 10.3.6 crash (organize Plug-In menu)
On first launch of v10.3.6, if there are too many plug-ins installed, the software will notify you that it will quit and that you will have to relaunch it. This only occurs when the plug-in cache is built. Unless you delete the plug-in cache, it should only happen on the first launch of v10.3.6.
Old 06-25-2013, 11:22 AM
Awww ok...I just booted it up just fine with the Nomad Factory folder removed from the plugin location...so you think that could have been the problem?
Old 06-25-2013, 03:35 PM
Post Re: Protools 10.3.6 crash (organize Plug-In menu)
The plug-in cache or the Nomad Factory folder? I think the plug-in cache is unlikely. I have seen Arturia plug-ins cause problems before, so I am more inclined to say Nomad Factory caused your problem.
Old 06-26-2013, 05:04 AM
Thanks Chief...really appreciate your time.
Old 06-26-2013, 05:29 AM
That kind of explains something that happened the other day after I used jcdeshaies program to trash my prefs and databases because 10.3.6 was acting a little weird. On the ensuing startup I got a notification that memory had run out and that PT would restart. On that restart the plugin scan and everything else ran just fine. What number defines 'too many plugins'? Is it the combined number of aax and RTAS plugins or what? I certainly don't have an inordinate number of plugins (under 200 total).
Jack
QAPLA!
Old 06-26-2013, 08:01 AM
Arrow Re: Protools 10.3.6 crash (organize Plug-In menu)
That information might be in the v10.3.6 read me. I do not remember what the numbers are, and that's if anyone at AVID ever did give me those numbers.
Old 06-26-2013, 10:09 AM
There's always been this nebulous 'too many plugins' but no one has ever been able to really define the exact number, at least here on the DUC.
Jack
QAPLA!
ORGANIZE PLUGIN MENU hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-21-2006 06:19 AM
How to organize plug-ins in LE 6.4 Kristian J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-10-2005 04:20 PM
Can I re-organize Plugins in Pull-Down Menu? d7guitar Tips & Tricks 7 12-06-2004 09:41 AM
ORGANIZE PLUGIN MENU BEATS BY KP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-10-2004 04:20 PM
How to organize plug-ins exit Pro Tools TDM Systems (Mac) 7 03-05-2003 11:45 AM
