Drive too slow errors (while disk usage at 0%)
I often get drive too slow errors while the disk usage is at 0% because the timeline is fully cached. How is that? Everything playing from RAM but PT says "can't get audio fast enough from drive because it might be too fragmented"? Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Drive too slow errors (while disk usage at 0%)
Perhaps your drive is going bad? Is there at least 30% free space on it?
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
Is that a (REQUIRED!) separate dedicated recording drive, or are you attempting to record to your system drive?
You have ram going bad maybe?
No to belabor the point, but if you're trying to record to the system drive, it's going to give you exactly this kind of fits. A dedicated audio drive is a must. From the PT compatibility page:
http://avid.force.com/pkb/articles/c...m-Requirements Audio Drive Requirements: One or More Hard Disk Drives Dedicated for Audio Record and Playback System Hard Drive: Minimum 15GB free space on startup drive required for Pro Tools installation Please note that they are treating the AUDIO and SYSTEM drives exactly as they are. Separate. This is one of the many places with Pro Tools where you can't take a shortcut. |
You might think, it's all in ram... shouldn't matter, but I've had all sorts of drive reading/writing issues... when it turned out to be the system drive.
Protools 10.3.10/11.3.2/12.6 | Win 7 Ultimate 64 bit |
0) I've been using PT since v4.3 and I know about the requirements, thanks.
1) I'm not recording 2) I'm playing back from an internal SATA drive 3) The same session runs just fine under 10 (no drive too slow errors) 4) Unlike 10 PT11 will pop up a "too slow" error pretty much every time I trim a clip while It's playing back (entirely from RAM). Something I do all the time in 10 with gigantic sessions. It somehow reminds me of the time when we get constant 9073 errors till AVID fixed it. (see those huge threads about 9073 from some time ago). The error seems to be back in 11. Not sure. Generally I was wondering why PT says it can not get audio fast enough from the drive when 100% of the timeline is cached. Frank.
BWAV, 48k, 24bit. split-mono.
Drive too slow errors after PT10 update | Tim R. | macOS | 4 | 12-21-2011 05:11 AM |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
"disk too slow errors" Run HardDrive Test | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-26-2004 11:24 AM |
DAE error -9060 & -9073 "disk frag or too slow" with new LaCie FireWire Drive! | mikerica101996 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-19-2003 08:56 AM |
Disk errors-9073 drive too slow | livstone | Pro Tools TDM Systems (Mac) | 14 | 01-29-2001 12:57 AM |
