new lap top with vista but only have ptle7.0
i was wondering if there was any way that it is possible to install ptle 7.0 then update to 7.4.1 so pro tools works on vista, or if there is any other way to get pro tools to work on vista?
Re: new lap top with vista but only have ptle7.0
7.4 is the only version that will install on Vista, so you will not be able to install 7.0 at all.
However the 7.4 upgrade is a full installer so if you qualify to get that, you can just install it directly on Vista. I believe the upgrade is $75.00 from the Digistore. It is a common misconception that because they call it an upgrade, you must first install the previous version. This is not the case. Hope that helps. |
PTLE7.4CS4 w/ 002 rack hangs on DAE Loaded in Vista | Scottbanger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-18-2008 10:04 AM |
Clipping when importing audio in PTLE7.4 vista | mark_b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-28-2008 08:37 PM |
Dell Optiplex 740 vista PTLE7.4 problem | cyberstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-25-2008 01:40 PM |
Vista questions before taking the Vista Plunge | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-21-2007 08:23 AM |
Microsoft announces Vista - Vista and PTLE | myfm | Pro Tools TDM Systems (Mac) | 2 | 07-24-2005 09:15 AM |
