Disable mac shortcuts
I'm really, really sorry for having to take up your time with this stupid question, but I can't find which system shortcuts to disable in order to get PT standards such as command+space to work.
I've already remapped spotlight search to cmd+alt+ctrl+space, so I'm somewhat at a loss here. And I can't find the instructions anywhere after 25 minutes of searching... Help, please. Thanks!
I just wanna do engineering... (as opposed to make music :/ ) |
Re: Disable mac shortcuts
system preferences/keyboard. Toggle on Use F1, F2, etc keys as standard function keys
Really? Do those affect cmd+space??
I have the same issue and the use all f key did not change it.
To disable Dashboard and Exposé:
1 Choose System Preferences from the Apple menu and click Dashboard and Exposé. 2 In the pop-up menus for each keyboard short- cut, set the shortcut to “–” to disable it. Disable or Reassign Mac Keyboard Shortcuts Used by Pro Tools To have the full complement of Pro Tools keyboard shortcuts, you need to disable or reassign any conflicting Mac OS X Keyboard Shortcuts in the Apple System Preferences. To disable or reassign Mac keyboard shortcuts used by Pro Tools: From the Apple menu, choose System Preferences. Click Keyboard. Click the Keyboard Shortcuts tab. Disable or reassign the following: Under “Dashboard & Dock” • “Turn Dock Hiding On/Off” • “Dashboard” Under “Exposé and Spaces” • “All windows” • “Application windows” • “Desktop” Under “Keyboard & Text Input” • “Move focus to the window drawer” Under “Spotlight” • “Show Spotlight search field” • “Show Spotlight window” Under “Application Shortcuts” • “Show Help menu” For a complete list of Pro Tools keyboard shortcuts, see the Keyboard Shortcuts Guide (Help > Keyboard Shortcuts). 22 Installing Pro Tools Software Reassign Spaces Keyboard Shortcuts If you want to use Spaces, you should reassign the Spaces keyboard shortcuts to avoid conflicts with important Pro Tools keyboard shortcuts. You can reassign Spaces keyboard shortcuts to use a combination of modifier keys (Command+Option+Control+Shift) in addition to the de- fault Spaces keyboard shortcut assignments to avoid these conflicts. To reassign Spaces keyboard shortcuts to use modifier key combinations that do not conflict with Pro Tools keyboard shortcuts: 1 Choose System Preferences from the Apple menu and click Exposé & Spaces. 2 Click the Spaces tab. 3 Ensure that Enable Spaces is selected. 4 Press and hold Command+Option+Control+Shift and select “Control+Option+Shift+Com- mand+F8” from the “To activate Spaces” pop-up menu. 5 Press and hold Command+Option+Control+Shift and select “Control+Option+Shift+Com- mand+Arrow Keys” from the “To switch between spaces” pop-up menu. 6 Press and hold Command+Option+Control+Shift and select “Control+Option+Shift+Com- mand+Number Keys” from the “To switch directly to a space” pop-up menu. From page 22 of the Installation Guide.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Handy little things, those READ ME files, manuals and Guides, eh?
“What fresh hell is this?” - Dorothy S. Parker |
Yes, I would think the installation guide would be the first place to look for installation info. Comes in handy.
An avid tech from repairs connected to my computer online because of issues with my second mbox pro went through and deleted my prefs and checked spotlight keys etc of which I already had set properly could not find the fix for getting record to work via command space bar. I may setup another user account on my mac pro and see if it works there it could be other software installed on my mac that's causing the issue. I love when people chime in and are snidely instead of helpful....Darney....
Well not really. |
There's also a cool free utility called FunctionFlip. Just google it. It let's you toggle the function keys individually. So for example you can disable the special functions for everything except the volume up and down. I do this when mixing on the internal soundcard.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
No apologies.
Disable Keyboard Shortcuts | rdrean | Pro Tools 10 | 5 | 12-08-2012 10:15 AM |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 09:42 AM |
How to disable Apple Shortcuts | emirruivo | Pro Tools 10 | 2 | 11-17-2011 11:44 AM |
disable triggering Quickeys Shortcuts when typing in text... | clusterer | Pro Tools TDM Systems (Mac) | 2 | 02-16-2010 04:27 AM |
TIGER UPDATE SHORTCUTS/disable | AKELCO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-11-2007 11:57 PM |
