volume automation not following edit
even though I have "Automation follows edit" ON I'm finding that volume automation is not always following. A perfect example is if I have an existing region ( take an ambs track for example) where the volume is just a straight line, if I stretch out the head or tail the volume line doesn't necessarily follow.
I don't have this issue in protools 7.4... in any way what so ever. Another trick I use to stretch out a head or tail is I use the key command "Option - or Command +" to fix a head or tail by a few frames and I keep having to show volume graphs and move the volume graph to the left or right to get rid of a massive pop in the volume curve. (I should also mention all these regions have fades on them I haven't tested this without fades) It's a major annoyance since you double up your work load every time you make tweak. Anyone else experiencing this, is it a known bug? |
Re: volume automation not following edit
I should also mention that's intermittent which is even more annoying.
At any rate, i'd love to hear if anyone else has seen or experience with this, perhaps it's a simple question of technique or not using a particular technique etc... |
I find this happening with copying and pasting a region. Automation does not follow
Automation follows edit vs edit writes new automation | RyanC | macOS | 4 | 10-12-2012 05:05 PM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
Volume Automation - Edit Window | stuseattle | Pro Tools TDM Systems (Mac) | 0 | 08-16-2010 01:58 PM |
Lighten edit window and thicken the volume automation line | Sukram | Pro Tools TDM Systems (Mac) | 26 | 12-09-2009 12:18 AM |
Edit Volume Level of a region without automation | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-12-2005 05:04 AM |
