Re: sgear help?????
Is the plug-in going into "Bypass" when you hit the record button?
Re: sgear help?????
We need a screen shot of your io setup screen
And a close up of your track inputs and outputs
Re: sgear help?????
screen shot
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram 500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE) |
Re: sgear help?????
screenshot
Re: sgear help?????
yes
#16
Re: sgear help?????
Is LLM turned off?
It should be off.
#17
sgear help?????
Here is another issue.
The pink circle is the output of your guitar track. The actual output needs to be the same as the blue circle. So make the guitar track output (pink circle), the same as the master fader output (blue circle). Also another issue I see, is the output of the io setup...says USB Audio codec or something. Your master fader needs to be routed there.... I also have a sneaking suspicion that your playback engine is not your interface....and it's your onboard sounds card. Search the PT Manual for playback engine and how to change it....
#18
Re: sgear help?????
And don't forget to activate input monitoring during record of course.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
#19
Re: sgear help?????
Thank you YYR123 turning off LLM did the trick. Geez what ever happened to "plug and play"
#20
Re: sgear help?????
I got it working by turning off the LLM. The pink circle issue was me routing to an aux track ,out of frame ,that is routed to submix which is routed correctly. thanks.
Latency with Steven Slate sgear Amp sim | rdpar | Pro Tools 12 | 12 | 04-25-2017 11:08 AM |
