002r mic inputs not working
people still using 002? just got one yesterday and wanted to give it a try. everything else seems to work ok except the mic pres and inputs. i get signal through line inputs 1-4 but nothing on the xlrs. any ideas?
Re: 002r mic inputs not working
Line 1-4 are working? Did you push the front buttons to switch from line to mic?(no offence, I just don't know how much you know about this stuff). In any case, if the line inputs work, and you have output sound, then you DON'T have the old "power harness" issue(a good thing). So back to the mic inputs, the front button needs to be set correctly. Then, if you are using a condenser mic that needs phantom power, IIRC, there is a Phantom power button for each pair(1&2, 3&4) in between the input jacks. If it STILL isn't working, you can use any number of external mic preamps between the 8 line inputs and the ADAT(lightpipe) inputs(the Behringer ADA8200 is a great budget option for that).
NO Inputs Working with 7.1.1 CoreAudio on 002R | sdevino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 46 | 08-07-2006 05:08 PM |
I need more inputs than my 8 from 002R? | Noviisi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-01-2006 02:34 AM |
XLR vs TRS inputs on 002R | mfavila | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 07-16-2005 06:17 AM |
Max inputs for 002R? | Anthonygallo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-08-2005 11:49 AM |
inputs into 002R | FinnJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-16-2003 08:13 PM |
