Onboard 1394 chipset
If I buy a motherboard with a Via chipset, will that do the job for onboard firewire connections, or should I still get a PCI card?
Re: Onboard 1394 chipset
Carl, the VIA chipset onboard firewire on my Asus K8V Deluxe works just fine with my Digi 002. I still have a VIA chipset PCI 1394 firewire card installed, but I use that strictly for external firewire hard disk drives... it's better to get each on their own firewire bus, but if you're sticking to just the 002 on firewire and internal IDE or SATA drives, you should be just fine with the onboard firewire controller alone.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
Thanks Phil, that's actually exactly what I needed to know!
fw-1394 chipset TexasInstruments "TSB43AB23"...works well? | johnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-21-2011 12:02 AM |
Is agere 1394 chipset compatiable with project mix ? | myonlineportal.com | Pro Tools M-Powered (Win) | 1 | 09-21-2007 02:42 AM |
ASUS A8N-E (No Onboard 1394 Firewire Port) | Digitalkidd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-29-2005 11:39 AM |
on board 1394 or separate 1394 card | PlayLoud | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-10-2005 03:50 PM |
915P chipset versus the 915PM chipset | valleyarts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-28-2005 02:22 AM |
