Wasted space in plugin windows is a drag
Are the common, Pro Tools defined, user interface elements of plugin windows cemented into place? I can understand the desire to keep consistency across plugins for the PT user, but for plugins that have are primarily vertical, there's a tremendous amount of unused grey space to the left and right of the centered plugin faceplate.
Avid needs to at least provide a condensed option (either reduced buttons or cut the layout in 1/2 and stack it) for the long horizontal layout of the elements at the top of the window as an option for plugin developers. I, for one, would very much like to see "micro" versions of plugins that reduce to meters only, or other displays reduced to critical info only. j |
Re: Wasted space in plugin windows is a drag
Can't say I ever noticed this here. Could it be a graphics issue on your system? (but, yes, I would love to be able to re-size the windows).
Only a very few plugins are small enough not to fit the PT plugin window! Then you get this blank grey area etc. Are you sure you haven't got view/plugin Mapping on? That will make the plugin window even bigger etc! Chris
Open the Dorrough meter from Waves and set it to "small" meter and vertical orientation. The meter is one plugin that I particularly want to leave open.
j |
Windows 8 Drag and Drop not working | notedmusic | Windows | 1 | 01-23-2014 09:18 PM |
How to drag-and-drop in Windows | colourednoise | Windows | 3 | 07-12-2013 01:53 PM |
Windows Explorer drag and drop audio files to PT8.0.3 | Buccanears | Pro Tools TDM Systems (Win) | 9 | 03-20-2010 09:05 PM |
TL Space Plugin - Not in plugin list? | joe.cavers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-31-2008 02:35 PM |
Sampler plugin with Drag & Drop from edit window?? | goldn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-07-2003 04:04 PM |
