Old 12-16-2006, 11:49 AM
robsubway robsubway is offline
Default midi track lagging
so, first off, I'm using my hd3 setup with a 1.6 ghz powermac/os 10.4/pt 7.2/2 gb ram.
when I try to play back a session, my midi tracks are all lagging. not consistently...just notes here and there. this is the first time this has happened. I'm pretty new to hd so I'm assuming this is some kind of settings issue. any ideas? thanks much.
Old 12-17-2006, 03:43 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: midi track lagging
I don't think this is a setting! is this internal midi or external midi with an interface?
If its internal then i would try using "save session copy" to create a new session and see if that helps!
If its external midi i would look at re-installing the midi driver and check all other connected devices! USB devices if your midi interface is USB and make sure its connected directly to the computer and not a hub.
could also try trashing all the prefs as described in the troubleshooting thread...
http://duc.digidesign.com/showflat.p...fpart=1#177661
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 12-17-2006, 09:53 AM
that's the weird thing...it's happening on midi tracks that are already recorded. I'll shut down and restart and it'll be fine for a while. but then it'll happen again later on. the track just plays back like a drunk guy trying to play piano...all stuttered. very strange.
Old 12-17-2006, 12:37 PM
Howardk Howardk is offline
Which Virtual Instrument plugins are you running? Are all you midi track outputs assigned an active port or VI?
See my Public Profile for System Configuration Information
(Click on member name)
Midi notes lagging/hanging/sustaining PyneBoxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-08-2012 08:42 PM
Midi lagging in Ableton Live 8.2 xterraguy MIDI 0 07-04-2011 06:24 PM
Click track lagging on playback evyngyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-29-2010 08:20 AM
PT is lagging soundwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2007 06:50 PM
Midi lagging behind in 6.9LE Digi2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-25-2005 07:39 AM
