Room measurement with REW
Hi all,
I'm new to REW and have a few questions. My mix room is equipped with PT Ultimate and Avid MTRX with Pro Mon. My REW rig is a portable Windows 10 laptop with the Roland Octapre soundcard. My monitors are JBL 708i for L-C-R and 705i for surrounds. Mics are Beyer MM1 with calibration files for 90 and 180 degrees position. I use 90 degree, mic is facing up (ceiling). In order to have the Pink/Sweep from REW played on my monitors, i have: - Output 5 from Octapre soundcard plugged into input 5 on MTRX - In Protools, on a mono audio channel, i have input assigned to input 5 of MTRX and Output is set to each of the respective surround channel as i take my measurement (L-R-C-Lfe-Ls-Rs). As recommended in the manual, Pink volume is set to 75dB via SPL meter. I usually take 4 measurements (mic placed at 4 different locations in the mix room) per channel, so 24 total. Will the set up above yield proper measurements ? Does REW offer mutli microphones measurements ? Thanks |
position of measurement for calibration | vudoo | Post - Surround - Video | 3 | 01-31-2017 01:16 PM |
Audio Analysis and Measurement | FifthDoctor | General Discussion | 10 | 01-13-2013 03:33 PM |
LIP SYNC (measurement) | Eric Seaberg | Post - Surround - Video | 2 | 05-26-2008 06:25 PM |
Audio measurement software | Gunnar Hellquist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-10-2004 04:28 PM |
Rack Space Measurement! | saeblee | General Discussion | 3 | 01-17-2002 09:15 AM |
