Not enough voices?
I just got the following message when opening a session I just recorded with 24 tracks....Any help?http://duc.avid.com/attachment.php?a...1&d=1431071633
System Details: Macbook Pro 17" OS 10.7.5 PT 10.0 8 gig ram FW Drives (Multiple) eSATA Drives (Multiple) [email protected] |
Re: Not enough voices?
that basically means that the session was done on a HD system and when you tried to open in natively, there's more playable track than native allows
session sample rate 48 / 96 / 192 kHz playable tracks 96 / 48 / 24 Although since you recorded only 24 tracks.. that seems odd. |
What exact version of Pro Tools are we talking about here? LE, SE, Express, First.....
I have 10.0 HD pro tools. The session it came from was HD PT11. I've even tried a new session and importing the audio and it does the same thing. Even 1 track......
I have no plug ins or inserts....Just trying to play the raw audio.....
So you import one track to a PT10HD session and it says you have ran out of voices? That doesn't seem right... Are you sure? Do you really mean you have a brand new empty session where you import one track and not enough voices?
That's exactly what happened. Even with 1 track of audio.....very strange and not sure how to get this to play.
So does your system work OK if you create a new session? Create a track and play back in that session? New totally empty session, not from a session copy, not from a template. If so then try just importing one track of the audio content (just the audio content) into that new session ... that audio content should not break anything. Make sure you are trying Import Audio *not* Import Session Data.
If there are still problems then try all the usual troubleshooting steps... trashing prefs, removing all plugin files from their RTAS and AAX folders (yes even if you are not using any plugins), testing from a new clean admin account, checking firmware and drivers are up to date, running digitest... |
Thanks Darryl, That's exactly what I did and still couldn't get it to play. New session and old sessions work fine. And seems to be only that audio from that session....
DSP and Voices | mwelles | Pro Tools TDM Systems (Mac) | 2 | 01-28-2010 09:09 PM |
dsp and voices ? | jackp | Pro Tools TDM Systems (Win) | 6 | 10-25-2009 11:29 PM |
How many voices???? | shanabit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-09-2006 07:54 AM |
what to do when all 32 voices are used? | time808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-14-2005 09:33 AM |
Voices,Voices,Voices..How to do it!? 002?MBox?HD? | TheMadStudent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-07-2005 09:16 AM |
