Just one more driver update for macOS Catalina!
C'mon Avid - dust off the code library one more time! Recompile the 11R drivers for 64-bit only macOS and it should work for several more years. Please?
That'd be great, thank you! |
Re: Just one more driver update for macOS Catalina!
Yes please, what he said!
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2024.3)| Pro Tools Carbon | Sibelius Ultimate (2024.3) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack | |
Not sure anyone is left that worked on it at Avid, which presents a struggle. Updating software you've worked on is easy. Updating software that others have worked on that has been carefully documented throughout is easy. Updating software that others worked on without good documentation? Really difficult. I don't know which of the three we're in but guessing #3.
I'd love for them to fix it, but for now running it into my Scarlett 18i20. I have found that the Editor works in 10.15.4 for me - so at least there's that...
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
The editor does work in Catalina? I thought it did not. That's good news.
It does indeed - I was surprised.
If AVID runs a professional development environment - and I assume they do - then they have decent documentation and code repositories and a competent developer could update the drivers with some nominal effort.
Did you just install the 11R Editor or did you have to install drivers as well? |
Drivers not installed, just the editor.
Every update of PT wipes out 11R editor for me. I get the MIDI engine error & 11R not available in PT Windows pull down menu. Seems that every MacOS update restores it Bummer because I update PT more frequently than OS Sent from my iPhone using Tapatalk
2019 iMac 27" 5k Retina 3.6 Ghz 8-Core Intel Core i9 Mac OS 10.15.7 / 60GB RAM UAD FW Apollo Duo (Thunderbolt Card) PT 2021.3 Eleven Rack FW v2.00.1 / Software 1.2.14 |
Something buggy in AVID's PT releases is messing up 11R
I'm curious - does rig-embed work? I had thought that only worked when the 11R was your primary audio interface.
Eleven Rack Compatibility with MacOS Catalina | guijacobucci | Eleven Rack | 87 | 07-21-2021 07:30 PM |
PT and Latest macOS Catalina (10.15.4) | rinky | Pro Tools 2020 | 3 | 04-29-2020 01:12 PM |
PT 12.5 and macOS Catalina | johnbarnesiii | macOS | 12 | 12-20-2019 03:02 PM |
Can EuControl 19.9.0 be used with MacOs 10.15 Catalina? | hanksinclair | Artist Series | 2 | 12-09-2019 10:54 AM |
macOS 10.15 (Catalina) and Avid Products | Avid | Technical Alerts | 0 | 10-07-2019 11:11 AM |
