Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 12-13-2019, 03:04 AM
stefanboman stefanboman is offline
Default S6 MTM noise
just wanted to check about this(somewhat)minor but annoying issue I've had since day 1 with our S6.
The MTM constantly make a high pitch acoustic noise, almost like crickets.
It's extra loud before I lock the Xmon to the S6.
My studio isn't overly quiet but I can still hear the MTM noise in the background.
I'm surprised that that a high end product like this isn't more quiet especially when a lot of the consoles are installed in extremely well built and quiet rooms.
Pretty sure it's not my unit that is faulty since I've had it replaced two times and all three units have had the same type of squealing noise.
Do all MTM make this noise?
Here's a recording of the noise from my phone.
https://www.dropbox.com/s/j34w6r3epu...noise.mp3?dl=0
Stefan Boman
Park Studios-Stockholm
www.parkstudios.se
stefan[at]parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 12-13-2019, 06:33 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: S6 MTM noise
I'm going to defer to Eddie on this one. I honestly haven't heard any complaints about this in the field for a very long time.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 12-16-2019, 03:35 AM
Eddie, any thoughts on this?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 12-17-2019, 02:10 AM
EddieJones's Avatar
EddieJones EddieJones is online now
There are a few things that can make noise on the MTM. The fan could not be switching off after booting into the MTM App (Easy to hear and see), The SSD has been known to have components go noisy...but most likely its the heat pipes making the noise, this can be heard if you do CPU intensive stuff on the MTM the noisy will change. This last one is not fixable unfortunately.
Old 12-19-2019, 07:17 AM
Thanks for the info Eddie.
It's not the fan as that shuts off after boot.
The heat pipes. What noise would they make? Noises when they change temperature?
Does not sound like metallic noises due to temperature changes.
Sounds more like some sort of "data flow" for lack of a better description.
Maybe it's the SSD? Maybe that's in more or less constant use between the S6 software and the Windows shell?
Are there different hardware revisions of the MTM?
Any changes over the years that could affect this noise issue?
Here's a better recording of the noise:
https://www.dropbox.com/s/yux010kun4...2%205.m4a?dl=0
Do you hear that on your S6s? Quite audible within a foot or two from the MTM.
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 12-19-2019, 07:47 AM
EddieJones's Avatar
There have been many revisions to the Master Module but none in that area. If you are under support you could ask Customer Service
Old 12-19-2019, 10:43 AM
I am. Will do that.
But does your S6 sound the same as the linked audio file?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 12-19-2019, 11:14 AM
EddieJones's Avatar
Its hard to tell from that file, sorry (I'm actually on Vacation at the moment too so can't check)
Old 12-19-2019, 11:56 PM
Sorry Eddie. Have a lovely vacation!
Any other users hearing this sound from their S6?
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 12-20-2019, 10:06 AM
Brandonx1 Brandonx1 is offline
No your MTM should not sound like that. Might be the ssd. Send it in and get a replacement. FYI make sure to get your files of the MTM before the RMA swap
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
