Old 01-07-2014, 03:40 PM
Dot Dot is offline
Default PT11 Quick Bounce Issue
I have an issue with offline bounce option in pro tools 11 (11.1.1) but every version I had, had the same thing going on. Each file i bounce has this weird sample rate issue type of sound each time i do it. Its really annoying when I bounce stuff and it sounds like that. Did anyone experience the same thing? I Run Win7 64Bit. I don't have any other issues with PT10 or 11. I attach the audio
https://www.dropbox.com/s/fbjd4qyq1jpphaj/error.wav
www.dominicdotokune.com
Old 01-07-2014, 04:44 PM
mesaone mesaone is offline
Default Re: PT11 Quick Bounce Issue
Have you tired an offline bounce with all plug-ins disabled?
Hold Shift while opening the session. This will disable every insert. Do an offline bounce. See if you get the same issue.
If not, then one or more plug-ins could be causing the issue. I haven't yet found a plug-in that interferes with offline bounce, but it's a possibility.
Old 01-07-2014, 05:27 PM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Exacly what Mesaone said regarding plugins. Members here have found a few iZotope plugins to be the culprit so if you can't get this right please list the plugins used on the error session and maybe we can figure out what is doing this to the bounce files.
Best of luck
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-07-2014, 08:44 PM
Dot Dot is offline
i had only 3 plugins in that session dverb, maxim and hofa project time
Did you disable them and try offline bounce?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 01-07-2014, 11:18 PM
Dot Dot is offline
i bounced offline with completely no plugins (i removed every plugin for test) (not bypassed, no deactivate just removed) still the same issue. My sessions are 48/24 and i bounced in 48/24
Old 01-08-2014, 11:06 AM
Originally Posted by Dot View Post
i bounced in 48/24
The file you posted to Dropbox was 44.1 kHz, 16 bit.
EDIT: sorry, I opened it in Audacity and it gave me the wrong wordlength. the file is 16-bit, not 32 float.
Old 01-08-2014, 10:03 PM
Dot Dot is offline
i just cut it in reaper for sample but it sounds like that anyway 48/24 or 44.1/16 same sound
Bounce to Quicktime Issues with PT11 fcobboe Pro Tools 11 1 12-01-2013 05:12 AM
Quick Question - OS 10.7.5 & PT11 grovephil Pro Tools 11 15 09-30-2013 07:43 AM
PT11 + VEP 5 Offline Bounce question. Connor Pro Tools 11 1 08-24-2013 03:34 PM
Bug Mp3 bounce after installing PT11 Leoslav Pro Tools 10 1 07-23-2013 08:04 AM
Serious issue with PT11 abre Pro Tools 11 3 07-01-2013 04:56 AM
