Old 05-14-2003, 03:31 AM
Eiko Eiko is online now
Default MicPre, how to...
Sorry, another MicPre thread
Now after reading a lot about mic pres here on the DUC, I started wondering about this: Say I have one without digital out, how do I actually plug everything together. A good pre should increase the quality of your recordings they said, but if I just plug it into DIGIs input, wouldn't that reduce the quality again? I mean, still Digis preamps and coverters are used as well.
Is this making sense?
With a digital out this wouldn't be a problem, as I wouldn't be using the DIGI preamps, but analog?
Any answers?
Cheers, E.
Old 05-14-2003, 03:56 AM
Manu Janko Manu Janko is offline
Default Re: MicPre, how to...
You can plug your Pre in input 3 to 8 (TRS), thu avoiding the pre stage of the DIGI hardware.
But, sure, the best way is to have a Pre-Converter (or one of each) and go dig.
But, again, you'll improve the quality ONLY IF what you use is better than Digi's.
Have fun. [img]images/icons/tongue.gif[/img]
Old 05-14-2003, 08:21 AM
where02190 where02190 is offline
Actually, you can plug into any of the 8 analog inputs, however, if you use inputs 1 or 2, engage the pad on the front to switch to line level.
Putting a killer mic pre into the 001's analog inputs would be a bit defeatist, however will improve your overall signal quality. Having an outboard converter as well would be more optimal.
Hope this is helpful.
Old 05-14-2003, 05:44 PM
Thanks for the replies. Quite helpful indeed...
...however, if you use inputs 1 or 2, engage the pad on the front to switch to line level.
<font size="2" face="Verdana, Arial">And turn the knobs all the way to the left I would assume. Am I right or wrong?
Thanks again,
E.
Old 05-14-2003, 06:14 PM
supro supro is offline
<font size="2" face="Verdana, Arial">You are right.
Old 05-14-2003, 06:33 PM
Cool, thanks...
E.
Old 05-15-2003, 07:56 AM
HornedHorse HornedHorse is offline
Where,
Actually, you really don't wan't to use the external preamp feeding the (padded) 001 preamps inputs - this will create a higher system cascaded noise figure than if you went directly into 3-8. [img]images/icons/shocked.gif[/img]
HH
Old 05-15-2003, 09:22 AM
TAPKAE TAPKAE is offline
You could always get an ADAT format converter box and stick any pre you want in front of it. Look for the Alesis AI3. Its just a converter box for 8 channels.
OS 10.3.9
1.25 mhz single G4, 1.25GB RAM, Firewire & Internal recording drives, Nomad Factory plugins
PT 6.4, 001, Motormix
Old 05-15-2003, 09:31 AM
Originally posted by HornedHorse:
Where,
HH
<font size="2" face="Verdana, Arial">We did some fairly major investigation into this, printing the same signals (test tones) into both the mic inputs with the pad engaged and the line inputs, and found there to be no difference in quality of signal.
Old 05-15-2003, 02:44 PM
...Or I could get a separate AD converter box thingy and thus not use 001 circuitry at all, except for getting the signal into my computer. Now that brings me to another question: What do you think is the minimum I'd have to spend for a AD converter to really improve my sound? Apogee sounds very expensive to me, so there might be cheaper solutions, maybe like mindprint. Would be really cool to get some answers on this one too.
Cheers, E.
focusrite micpre repair bradp General Discussion 4 08-09-2012 09:26 PM
Please if anyone can give some advice on micpre... .tel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-06-2006 11:42 PM
C24_focusrite micpre´s ?? Redhouse_Janke ICON & C|24 2 11-11-2005 05:03 AM
Micpre or focusrite? rage_ele 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-03-2003 09:56 AM
Does anyone know this MicPre? King Kong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-01-2002 03:07 AM
