Old 08-23-2002, 06:32 AM
stickarms stickarms is offline
Default Pro Tools lock-up
Hello,
I've been using the Digi 001 for about a year now and I always experience random lock-up's while I'm using it. When it locks up, I'm able to hit Ctrl-Alt-Del and save my session before I "end task" and reboot, but nothing else will work and my mouse completely locks up as well. I am running PT LE on a Windows 98-SE machine with 512 MHz of RAM. At first, I thought the problem was my mouse, but I've tried several and I still have the same problem. This is one of the only real problems I have with the program, but it is very frustrating. Can someone please give me some guidance on how to possibly fix this problem? Have any of you had this same problem?
Thanks, I would greatly appreciate some help. -------------------Stickarms
Old 08-23-2002, 06:44 AM
DigiTechSupt's Avatar
Default Re: Pro Tools lock-up
-How are the resources in your system allocated?
-What resource has Windows assigned the Digi001?
-Is anything else sharing with the Digi001 device?
In the meantime, disable all startup items:
1) Start Menu > Run > Type in: msconfig > OK > System Configuration Utility Menu appears > Startup Tab.
2) Disable startup items that do NOT have C:Windows in explanation.
3) Do NOT disable: Scan Registry, System Tray, and Load Power Profile (both).
4) Disable all other items that might appear.
Brent
Avid Audio Tech Support
Support FAQ
When oh when will we be able to "lock out" tools and modes?? Drew Mazurek Pro Tools TDM Systems (Mac) 34 01-09-2008 07:56 AM
Graphics lock up in Pro Tools 7 stuie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-14-2005 10:53 AM
Panther 10.3 and Pro Tools Lock up El Jay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-28-2003 10:49 AM
SSD receives LTC but Pto Tools 4.1.1 doesn't lock? CHARLES XAVIER JR Digidesign Hardware & Software 2 01-08-2003 03:39 PM
Pro Tools Lock Up!!! Smakrabit Digidesign Hardware & Software 1 04-13-2002 01:45 PM
