7.4 becomes unresponsive
G' Day.
I just bought an MBox micro and installed it on my dual 1.8GHz G4 quicksilver (1GB RAM, OSX 10.9). Previously I was running OSX 10.11 and PTLE 7.3.1cs5 with an MBox 1 without a hitch. Now, under 7.4, even a small session hangs after a few mins of playback, looping a short section of audio endlessly. After a few seconds, I do regain use of the cursor and can place it anywhere on the timeline but Protools will no longer resume playback. I have tried everything suggested here, Re-installed the OS and brought it up to 10.9, deleted all prefs and database files, checked permissions, removed all plug ins, but to no avail. The problem persists even if I substitute my original MBox for the micro. My laptop config (1GHz g4 powerbook, 2GB RAM, OSX 10.11 PTLE 7.4) runs fine under both sets of hardware, and again I did not have these issues on the tower with 7.3.1cs5. my playback engine settings are as follows: Buffer - 1024 RTAS Proc - 2 CPU Limit - 90% • ignore errors during playback DAE Buffer 1500ms (level 2) Cache - Normal Any ideas? TIA
Neotech Concepts http://www.imdb.com/name/nm0235036/ ! sonic gymnastics for the illusionary arts ! 2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch, EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB |
Re: 7.4 becomes unresponsive
How did you get a dual 1.8ghz G4 Quicksilver? I assume there's some sort of upgraded CPU card in there, and that may be what's causing your problems. Note that Quicksilver models are not qualified for use with 7.4 and fall under the "not recommended" category here.
D-Command unresponsive | DaleB | ICON & C|24 | 2 | 03-23-2013 01:51 AM |
PTMP 8.0.3 Very Unresponsive | JMKeupp | Pro Tools M-Powered (Mac) | 2 | 05-18-2010 06:46 PM |
M-Box is Unresponsive | TheForgottenXVII | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-18-2009 05:22 AM |
PT8 becomes unresponsive on playback | AdamThompson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-20-2009 10:01 AM |
Unresponsive Automation | NK | Pro Tools TDM Systems (Mac) | 1 | 11-08-2001 10:00 AM |
