Re: Pro Tools 12 Application Manager Question
I can find the app in Finder but not whats starting it up. The only thing I can think of is the startup file must be hidden.
Change the RunAtLoad key to false in the com.avid.ApplicationManager.plist file
in the Macintosh HD->Library->LaunchAgents There is a RunAtLoad key also in the com.avid.ApplicationManagerHelper.plist but I think better keep that as true otherwise might not work when you start Application Manager manually. You can change the file with Text Editor but make sure that the extension is plist and not changed to txt or rtf. (or download Plist Pro http://www.fatcatsoftware.com/plisteditpro/ or use XCode if you have that installed) Jesper Last edited by jesele; 05-11-2015 at 10:20 PM. |
Seem to work fine here anyway.
Let me know if you get into trouble. Jesper |
It's working fine here too. Thanks!
#16
Brilliant.
Jesper |
#17
Thanks guys. Great explanation as to what it does.
Now it seems almost needed. So I guess I will download it and instal it. Glad the issue seemed to be figured out here as well.
ROULETTE RECORDS™ (415)334-8742 office (267)219-4490 fax www.rouletterecords.com [email protected] Any fool can complicate things; It takes a genius to simplify them __________________ |
#18
This may be you are looking for....
https://support.apple.com/kb/PH18786?locale=en_US Go to log out or shutdown and uncheck "reopen windows when logging back in" Maybe this has been stated, but if you had pro tools open and shut down the computer it will the mac will launch whatever apps were running at the time of shutdown. |
#19
Not impressed so far.
Sonny Keyes Toronto http://www.sonnykeyes.ca Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20 Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10 |
#20
I just installed PT12 and have the same issue. I don't want application manager to load at startup but it is no in the login items of my user account.
i don't use PT that much and i don't want it taking up resources unnecessarily on my Mac. i see the value of this program but don't see the need to have it running all the time. Avid, please tell us how do disable this automatic start at login function. Thank you! |
Avid Application Manager System Usage | ShiftStudios | Pro Tools 12 | 3 | 04-17-2015 04:05 AM |
Application Manager | hooksound | Pro Tools 12 | 0 | 04-08-2015 10:00 AM |
Session and PT application not launching together | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-23-2008 03:02 PM |
Pro Tools Quits when launching application, help! | S133 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-02-2006 10:50 AM |
Launching Pt free: Application (null) has quit | ajohn | Digidesign Hardware & Software | 2 | 02-25-2003 06:36 PM |
