Anyone else get this? PT8.0.1 crash w/ Firefox
This has now happened too many times to go without discussion:
I have a ProTools 8.0.1 session open (any session). Everything is working fantastically. Zippy worky work work and I'm productive. Clickety click everything's fine. I need to access the 'net' (as in "the internets"). OK. I removed IE 8.0 to be kosher with ProDrools. I'm now using Mozilla Firephaux. Whenever I use Firefox to access the "internets," my ProTools session crashes with a frozen screen and then after 2-3 minutes, an offer to "report the error to Microsaupht." Huh? And after experiencing this several times, I can tell you it's real. Open a session in PT8.0.1. Minimize it to the taskbar. Open Firefox and peruse the net Try to maximize the ProTools session and I get a frozen white screen. hmmmmmmm.... Otherwise a fairly solid system. Of course, here's the obligatory Sandra report: SiSoftware Sandra Computer Model : Gigabyte EX58-UD3R Workgroup : BEEZER Host Name : music_hog User : Michael Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD3R BIOS : Award (Phoenix) F4 02/26/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.38GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ASUS Extreme AX300SE/T (4 PS2.0, 2 VS2.0 324MHz, 128MB 195MHz, PCIe 1.00 x16) Storage Devices WDC WD3200AAKS-00L9A0 (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:) (F:) WDC WD1600AAJS-00L7A0 (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 149GB (E:) WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 233GB (G:) (I:) LITE-ON DVDRW SOHW-1693S (RAID, DVD+-RW, CD-RW) : N/A (D:) LITE-ON COMBO SOHC-5236V (RAID, DVD+-R, CD-RW) : N/A (H:) Logical Storage Devices Hard Disk (C:) : 195GB (NTFS) @ WDC WD3200AAKS-00L9A0 (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) System Imag (F:) : 103GB (NTFS) @ WDC WD3200AAKS-00L9A0 (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) BFD data (E:) : 149GB (NTFS) @ WDC WD1600AAJS-00L7A0 (160GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) 250Gb Aux1 (G:) : 155GB (NTFS) @ WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) SSD Backup (I:) : 78GB (NTFS) @ WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (D:) : N/A @ LITE-ON DVDRW SOHW-1693S (RAID, DVD+-RW, CD-RW) Optical Drive (H:) : N/A @ LITE-ON COMBO SOHC-5236V (RAID, DVD+-R, CD-RW) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Serial Port(s) : 1 Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft Office Document Image Writer Driver (300x300, Colour) Printer : Lexmark 2600 Series (4800x4800, USB, Colour) Network Services Network Adapter : Linksys WMP110 RangePlus Wireless PCI Adapter - Packet Scheduler Miniport (Ethernet, 54Mbps) Network Adapter : Realtek RTL8168D(P)/8111D(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 ______________________________________________ I'll see if I can get a screen crapture video. Give me a few minutes to find something like that on "the internets."
____________________________________ Home Build: Core i7 920/Gigabyte EX58-UD3R/6Mb Ram Mbox2/MboxMicro ProTools 8.0 |
Re: Anyone else get this? PT8.0.1 crash w/ Firefox
Oh the irony...
I install Debut Video Capture and run a screen capture test only to have the bas+erd work just fine... Maybe the magic is in posting a problem and then have the gremlins make it go away to have me look the fool. If I post about ADC and try to screen capture that, will it suddenly go away too?
Hmmm....my best advice is not to open Firefox while Pro Tools is open. PT doesn't seem to like to share the computer with anything else.
Most of the time this is how my bug reports go... I rant and it fixes itself.
FWIW I've had unresponsive PT with firefox before, but not too often and I have firefox running all the time. hmm how long till someone chimes in with a comment about internet connections on PT computers....in 2010 this is the reality of the project studio and any modern computer should be able to handle an idle internet connection in the background.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
My MAIN rig has an idle 'net connection at all times without a hitch, but I RARELY go online with it, other than FTP uploads. BUT my BACKUP rig in my office has an M-box, and I go on the 'net all the time with it...I can even record internet audio off my PC soundcard into the Mbox with it. So it's advised against, but I do it all the time.
The session I've been using lately has some pretty intense plug-ins on it. BFD2, Ozone 4, Steven Slate Drums via Kontakt 3, Nomad trackbox, Recitfi, and Smack (amongst a lot of others).
Maybe it's one of those plug-ins having its "special monthly lady-time."
____________________________________ Home Build: Core i7 920/Gigabyte EX58-UD3R/6Mb Ram Mbox2/MboxMicro ProTools 8.0 Last edited by Herkimer; 03-31-2010 at 05:56 PM. Reason: bad punctuation |
Try Kontakt Player 4 instead of 3?
Maybe Kontakt 4. Is it free? I got Kontakt 3 as part of the Steven Slate Ex package on Audiomidi.com. I followed the install directions and that's what I got. Never had Kontakt before and completely unfamiliar with it (other than it works well with that Steven Slate Thingamajiggy which I like a lot: http://duc.digidesign.com/showthread.php?t=268813).
so you actually have 3.5. the newest version is Kontakt Player 4. I don't know what's going on in the coding as far as stability but I find it a little nicer to look at and use.
http://www.native-instruments.com/#/...ontakt-player/
I don't imagine that it is an inherent Pro Tools / Firefox compatability issue. I use my 002 rack and PT8 to record audio from the internet (using Firefox) via the computer's sound card all the time and have never had a any kind of problem with the two programs. If your problem resurfaces, it must lie somewhere else.
Intel P4 3.0GHz, 2GB RAM, Win XP Pro build 2002 SP3. 002 Rack. Pro Tools LE 8.0.1. |
Firefox 4 is crap... | Top Jimmy | General Discussion | 29 | 08-06-2012 01:40 PM |
Firefox 4.0 and iLok.com is a no-go!!! | mykhal c | Windows | 8 | 04-09-2011 11:44 PM |
Does the DUC only Suck on Firefox?? | propower | General Discussion | 11 | 04-22-2010 05:07 AM |
No Audio on firefox | gclef101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-10-2009 06:16 AM |
iLok.com and Firefox | JCBigler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-15-2005 04:32 AM |
