Old 03-10-2008, 08:08 AM
studiokeyz studiokeyz is offline
Default live trax
Hey question. I'm running pt 7.3 for background tracks with groups I play for. I waas wondering how I can bus it out to only send the click track to the drummers headphone amp? I have other instruments as well but I only want the drummer to hear the click track. I know I would need a headphone amp, but would I set everything up from pt and the amp
Old 03-10-2008, 08:42 AM
Palli-Moon Palli-Moon is offline
Default Re: live trax
I'll do my best to try to explain this. Basicly the first thing that matters is what interface you are using. How many outputs you really have, say you have the good ol' mbox you have 2 outputs and there's no way for you to get more. So if you want to use a headphone mix you can only have 2 mono mixes. The way to route to the headphone mixes would simply be to use the interface outputs as the output of the the channel or bus it to an aux you use for head phone mixes.
Lets say you want only bass and clicktrack in the drummers hp mix you can bus those two channels to an aux with the output set to the desired output, then for the rest of the band you can use the original out puts or create a 2nd aux in a similar way as the drumers hp mix.
I've probably confused you more than I've helped, but it's worth a shot
Old 03-11-2008, 07:44 PM
Would the presonus hp4 be good for this? I'm thinkin about purchasing one. I have a behringer ha4700 @ my studio but want something more portable for live shows
PT trax to Nuendo bbob Pro Tools TDM Systems (Mac) 2 03-31-2005 03:43 PM
HOW DO YOU GET YOUR TRAX FROM CD INTO?? TACT OUT MUZIC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-02-2004 04:05 PM
how many aux-trax will 6.1 offer?? clusterer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-13-2003 07:06 PM
IF YOU UPGRADE TO 6.0, DO YOU LOSE YOUR 32 TRAX??? TACT OUT MUZIC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-12-2003 04:52 PM
HD-1 How many trax,plugs@44 which I/o? fourthtunz Pro Tools TDM Systems (Mac) 0 06-02-2002 09:54 PM
