Old 09-21-2009, 08:49 AM
Kewl Kewl is offline
Default Slow start on play
I have two systems with the same problem: PT HD 8.0.0cs3 (downgraded from 8.0.1) on a Quad G5, 8 GB RAM, 10.5.8.
On play or record, PT takes about 3 or 4 seconds before starting to play. On stop, playback stops instantaneously. I fiddled around with a few settings in the playback engine, but to no avail.
There seems to be a few threads describing similar problems and I sort of noticed that the G5 was a common element in those threads: is it so?
- Daniel
Old 09-21-2009, 09:02 AM
Stig Eliassen's Avatar
Default Re: Slow start on play
Pre-roll on?
Old 09-21-2009, 10:07 AM
FajitaTone FajitaTone is offline
Mac audio output set to digidesign core audio
switch it to internal
Ray Trujillo
Freelance Audio Engineer
Old 09-21-2009, 11:16 AM
Craig F Craig F is offline
Open-ended record allocation?
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 09-21-2009, 11:21 AM
DigiTechSupt's Avatar
Do you have video in your sessions? If so, try changing the Sound control panel to 'Built-In' as having it set to Digi HW can cause this playback delay.
Avid Audio Tech Support
Support FAQ
Old 09-21-2009, 11:55 AM
Yup, that was it, thanks. Is this also a problem with 8.0.1? Can I safely re-update to 8.0.1?
TIA,
Daniel
Old 09-21-2009, 08:10 PM
K.I. K.I. is offline
Hi.
I am making the work drive SSD.
It operates at considerably and high speed without trouble.
OCZ
SSD is ..Vertex Series SATA II 2.5 ".. recommended.
http://www.ocztechnology.com/product...ata_ii_2_5-ssd
Old 01-01-2010, 03:59 PM
XXPepper XXPepper is offline
Daniel
FYI: we experienced this same "video delay on play" symptom after upgrading to 8.0.3 on Snow Leopard (10.6.2).
Solution was the same (and thanks for posting that!): Go into the OS-X sound preferences, and explicitly set the output to "Built in".
Old 01-24-2010, 07:12 AM
Ken Skoglund Ken Skoglund is offline
Here is another cause for that. I had the same problem, cutting a 20 episode TV show on a PT LE 8.01 system (OS 10.5.7) with DV toolkit. Adding episodes as the video editor finishes them in chunks. I have all episodes in the same session, 2 videotracks. It was fine from the beginning, then PT suddenly had a 3 sec delay on play. My OS sound prefs was set to internal all the time.
I found the problem and it was one of the video files, all videos had no sound track (format was H264 1024x576 25 fps). One of the videos though, had sound (at 44.1), I did not import any audio from the videos, but that one file was slowing down the whole system (session running at 48k). I removed the soundtrack on the videofile and play delay was gone.
Old 06-08-2010, 04:22 AM
sonicam sonicam is offline
Thanks for that Ken, best tip i've ever had from the forum!
My video's were converted without sound option in quicktime but on inspection in quicktime pro (apple + J) there was still an audio track.
Deleted that and all was fine.
Works on PT LE also btw.
http://www.sonicamusic.co.uk
very slow start up kemosabi73 Pro Tools 9 17 09-11-2011 04:14 PM
very slow start up kemosabi73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-17-2010 11:52 AM
7.4 LE Slow start up pixmixer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-07-2008 05:28 PM
PT LE Slow to Start Len8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-09-2007 08:02 PM
PT slow start up HELP! etherealproducer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-03-2005 11:23 PM
