Old 04-21-2009, 02:47 AM
sonicam sonicam is offline
Default can i install PTHD 7.4 and PT 8 on the same system?
we would like to try out PT8 but keep our PT version 7.4 installed.
is this possible if we setup different user and have the different versions?installed in each.
I suppose i could install osx and PT8 on a firewire drive and boot from that, but its alot of effort....
Old 04-21-2009, 02:55 AM
aux aux is offline
Default Re: can i install PTHD 7.4 and PT 8 on the same system?
No, I don't think you can run 7.4 and 8 from 1 disk, even with different users. Better use an extra disk (internal or external) to install a new OS X with PT 8.
Aux
MassiveMusic
SOS article
Old 04-21-2009, 03:33 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by sonicam View Post
Best to clone your system drive using "carbon copy cloner" and install pt8 on the cloned drive and just boot up which ever system you want top run.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-21-2009, 12:36 PM
Media Man Media Man is offline
I have Tiger/PT7.4 on one partition and Leopard/PT8 on another partition of the main system drive.
I got there as others have suggested, using Carbon Copy Cloner to clone Tiger/7.4 to a external FW drive, and then reformatting the system drive to two partitions.
Install Leopard/PT8 on one, and clone back Tiger/7.4 to the other.
As a safety net, I always "eject" the boot up partition that is not in use to keep sneaky little files from finding there way around during plug-in installs, etc.
mark
Old 04-22-2009, 10:00 AM
cool, thanks guys.
FCP & PTHD on the same system? rhumphries Post - Surround - Video 7 11-21-2008 12:24 PM
TC System 6000 integration with PTHD Mixchump Pro Tools TDM Systems (Mac) 16 03-05-2004 05:26 PM
Noise from PTHD system stuarta Pro Tools TDM Systems (Mac) 7 02-23-2004 05:34 PM
RTAS on PTHD system Jeff D. Pro Tools TDM Systems (Mac) 1 04-17-2003 12:12 AM
Stick with Mix System or Go For PTHD? Cauldronics Pro Tools TDM Systems (Mac) 2 07-16-2002 09:26 AM
