Old 04-17-2009, 06:11 AM
sonicam sonicam is offline
Default Digi Hardware with Logic?
I'm trying to get more than 8 outputs from Logic with Digi hardware.
I have Logic 8 running core audio to a Digi 192 interface.
I also have 2 x Digi 888 boxes hanging off the 192 and was hoping for 24 outs (as with Protools)
However Logic can only 'see' the 8 outs.
I've been through the DAE conversions etc, but it just seems so complex and cumbersome.
Does anyone know a way to make logic 'see' the extra boxes? If I were to buy a 192 expansion card (or another 192), would that give me 16, or can core audio only see 8?
Surely there must be loads of people doing this? No?
Cheers!
Old 04-17-2009, 06:46 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Digi Hardware with Logic?
Cheers!
8 is the limit with coreaudio and digi hardware.
You'll have to use the DAE driver to use more than 8 i/o in Logic. using the DAE driver means the main logic mixer can't use logic plugins but TDM plugins instead. there is a way of having a second mixer in logic to use logic plugins and instruments and route this second mixer to the main mixer. this is called using the emagic system bridge, but not too sure how well it works currently or if it works at all.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2009, 09:43 AM
David Pye David Pye is offline
It works fine, it's far from the most elegant way of working though. Personally I much prefer a fully Native system for running Logic and leave TDM to Protools.
But thats not to say you won't get on just fine using DAE/DTDM. It just feels much more awkward to me.
Just remember that Logic Software instruments, or audio tracks with Logic plugins, must run on DTDM tracks, and must be routed through an ESB bus to the a DAE aux input. When you get your head around that, it'll all be fine.
Using Digi hardware+Logic under Core Audio nwilliams Pro Tools TDM Systems (Mac) 2 07-08-2005 05:46 PM
For those using Digi hardware and Logic 7 PTgeek911 Pro Tools TDM Systems (Mac) 1 05-24-2005 05:45 AM
Anyone here use LOGIC or other VST apps with their digi hardware?? el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-30-2003 02:50 PM
Can I use Digi 001 hardware to record into Cubase or Logic 4.6? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-14-2001 07:32 AM
Digi 001 hardware + Logic Audio thetan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-05-2000 08:54 AM
