Old 10-18-2021, 08:09 AM
MixerGuy MixerGuy is offline
Default help please - Avid S1 just stopped connecting to ProTools - software setting issue?
EDIT - i fixed my own problem.
solution - after trashing PT prefs (as evidently I had recently)
- go to PT Peripherals / ethernet controllers / and *enable* ethernet port - on Ethernet 1
and also down below Enable EUCON.
otherwise it won't work at all.
this fixed the non - connection issue.
was working fine for months
I'm no expert on Eucon or other settings.
any ideas? thanks.
the faders just have one little low down thin rectangle above each fader. in the LED (?) display.
no other lights.
Catalina 10.15.7
PT 2021.7
EuControl 20.6.1.3
Firmware is up to date on S1 (I checked)
Eucon Workstation v4.6.2x3 (see screen grab)
I have a proper ethernet cable (i forget the specific name, but it hasn't been changed, and yes both ends are seated well. Just reseated them)
it is plugged into the *upper* ethernet port on current (2019) MacPro
Yes have restarted both MacPro and S1.
any ideas? many thanks
Old 10-18-2021, 08:54 AM
Default Re: help please - Avid S1 just stopped connecting to ProTools - software setting issu
Good detective work Trashing Prefs resets many things, including Eucon(gets turned off), HUI(gets turned off), Auto-Backup(gets reset to default). Its worth going thru Prefs and taking notes, or saving screen captures. Also, for those using HDN or HDX cards and interfaces, hardware gets reset to defaults. With 192 and HD IO's, that can cause all your digital IO paths to quit working. Once I got all that reset for the 4 units I had, I saved screen captures for all of it.
Avid MC editor setting up for ProTools and Mix kylerboudreau Post - Surround - Video 6 12-09-2021 10:18 PM
Connecting Avid Video Engine PT11.3.1 software albertocarlassare Pro Tools 11 5 05-21-2015 11:32 AM
AVID software license agreement issue insightsono Pro Tools 11 5 03-22-2015 04:12 PM
connecting hardware insert to the 003+ / setting it up properly in protools le elmuerte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-06-2010 03:52 AM
motif es issue connecting to protools vapp MIDI 7 12-28-2006 06:03 PM
