Old 10-10-2021, 02:47 PM
zigzawya zigzawya is offline
Default Custom knobs mapping file location on a mac
In this video it's mentioned that "this also saves the map to your workstation
so you can back the file up or even copy it over to another system"
https://youtu.be/6v9mnPNUi6g
Does anyone know where that file is located on a mac?
Old 10-10-2021, 06:00 PM
mattrixx mattrixx is offline
Default Re: Custom knobs mapping file location on a mac
The custom Knob Map .xml files are located in -
~user / Library / Preferences / Avid / Consoles / "here"
Note, it is not one file. It is an xml file for each custom mapped plugin.
The export function in Eucon is for application soft key sets.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-11-2021, 06:35 AM
Thanks for the reply!
Unfortunately there's no such folder on my system,
maybe it's a difference between the S1 and the S3?
Old 10-11-2021, 06:42 AM
its2loud its2loud is offline
The User/Library folder is a hidden folder in the Mac OS. You will need to show hidden folders or press Command+Shift+period[.] while focused on the finder to show hidden folders.
https://osxdaily.com/2018/02/12/show...oard-shortcut/
Old 10-11-2021, 07:31 AM
Thanks again!
Still there's no console folder in the avid folder.
Macintosh HD / User / Username / Library / Preferences / Avid / looks like this:
Pro Tools (folder)
Project Locations (folder)
Space Packages (file)
(Checked this one as well -> Macintosh HD / Library / Preferences /
but there's no Avid folder there)
Also did a finder search for "Console" but without any success.
Old 10-11-2021, 03:00 PM
Have you created any plugin maps yet?
Matt McKenzie-Smith
mattrixx.net
Old 10-12-2021, 06:02 AM
Thanks mattrixx, yes a couple and they all work when restarting Pro Tools
so they must be saved somewhere on the computer...
Old 10-19-2021, 10:43 AM
If anyone else have the same problem I've made a workaround..
In the Avid folder, manually create a folder named Consoles with a subfolder named KnobMaps,
now all your custom mappings xml files will end up there.
Old 10-20-2021, 07:53 AM
EddieJones's Avatar
What kind of account do you sign into the Mac with? I don't think anyone has seen this before and it could be a user permissions thing.
Old 06-15-2022, 02:41 PM
reichman's Avatar
reichman reichman is offline
Thanks mattrixx! I'm setting up a new rig and I was stuck trying to figure out how to move my custom maps. All good now. 👍
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Custom plugin mapping for knobs?? stefanboman Avid S4/S6 24 06-29-2021 06:56 AM
Mapping MIDI CC's to Faders/Knobs? KeyplayerG Artist Series 9 08-14-2018 10:42 AM
Mapping of surround pan knobs on Mix/Control espron Artist Series 0 01-03-2018 12:24 AM
ProControl - Mapping Plugins on Knobs Dario Ramaglia ProControl, Control|24, Command|8 6 07-05-2014 03:05 PM
Re-mapping AIR VI knobs Gothboy Virtual Instruments 2 06-23-2009 06:54 AM
