Re: Crackling in record mode in pro tools
Not necessarily true. Traced an issue years ago to the length of the usb cable to an Mbox. And in both cases, the cable lengths were within USB specs just that with any longer cable, the mbox would work (and be identified) but sporadically there'd be glitches. With shorter cables it was fine.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 11-04-2018 at 07:26 PM. |
Thanks new to this forum thing
I did mess with the buffer settings but not the plug ins I will try that thanks
Given this bit of news and if you're truly running the PT7 version you say there's still the possibility of non-compatibility to think about. This may or may not be the source of your problem but can't be discontinued either.
There is a possibility that the power feeding the Mbox might be an issue then again you haven't said what specific Mbox you have and how it's powered. Nor have you said what specific iMac you have either. There's no such thing as TMI (too much info) when asking for help here. As someone here said put you specs in your sig file or do like me and put it in your profile with a note in your sig file to look in your profile for the specs. |
No Audio In Record Enabled Mode Pro Tools 11.3.1 | shamanrock | Pro Tools 11 | 2 | 03-23-2015 10:16 PM |
Pro Tools crashes when entering record mode | matt0722 | macOS | 2 | 06-20-2014 09:01 PM |
Pro Tools LE 8 Plays/Record with Outbursts Loud, Scratchy, Crackling, White Noise.. | apdunshiz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-12-2011 05:16 PM |
Pro Tools HD 8.0.4 Huge Record Mode Delay | BJohnston | Pro Tools TDM Systems (Mac) | 13 | 08-21-2010 02:11 PM |
Crackling in record mode (even when not actually recording), cannot record > 10 secs | chandra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-16-2010 09:08 PM |
