No Audio with Elastic Audio
I'm new to elastic audio but I thought I pretty well had it figured out. I applied it to an 12 minute acoustic track to tempo correct manually using X-form. It isn't committed yet, but suddenly there's no audio. I see the waveform but when I try to play it, there's nothing. Any hints?
Re: No Audio with Elastic Audio
It is likely that that the audio is being rendered. X-Form takes a very long time to render and once you make ANY changes to the audio whether it is splitting, trimming, quantizing or anything, it will go back through rendering the audio before you will be able to hear it again.
I recommend using one of the other elastic audio algorithms such as Polyphonic until you have the file exactly the way you want it. Then switch it to X-form and give it 20 minutes or so to render it. Once it is rendered, you will hear it again.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Elastic Audio can't render-then loses audio file | boneboy | macOS | 5 | 04-30-2014 04:57 AM |
Elastic audio taking VERY long to analyze audio? | DJ Hellfire | Pro Tools 11 | 3 | 07-03-2013 05:44 PM |
PT10 elastic audio unable to analyse audio files | chinopepito | macOS | 8 | 03-30-2013 11:03 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
Using Elastic Audio match to tempo without affecting the audio | Silvio | Pro Tools 9 | 5 | 06-21-2011 09:41 PM |
