Old 03-16-2018, 12:27 PM
tkuerrev tkuerrev is offline
Default EDL - which software to open an edl
Hi there,
I got an .edl file from a video editor. But I don't know how to open it so that I can see what's written. I tried to just write the ending ".txt" instead of .edl to the file, but it didn't help.
Any hints which software does the job? I use Pro Tools 2018 on a MAC Pro. I don't use any video software, I am audio specialist only.
Thanks for any hints.
Old 03-16-2018, 01:40 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Default Re: EDL - which software to open an edl
Originally Posted by tkuerrev View Post
Hi there,
The TextEdit usually reads EDL text file without adding .txt.
Conformalizer by The Cargo Cult opens it as well.
I am not sure what you are trying to achieve though?
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 03-16-2018, 01:45 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
If you have Excel you can try opening it with that from the .edl or your version renamed to .txt It should give you the option to set the new workbook to Tab Delimited.
If not you could send me the file and I can convert it to text from Media Composer.
Andrew (andrewatactiontvnz.com)
Old 03-16-2018, 03:38 PM
conleec conleec is offline
Any EDL that we can do anything with is just a text file and can be opened in your favorite text editor, with or without renaming it. If you can't open it, then it's some sort of proprietary binary file and you'll have to ask them to redo as a standard text EDL.
Chris Conlee
PTHD 2018.1, Behringer FCA610, Blackmagic Intensity Pro (driver v10.8.2)
Mac OS 10.13.2, 2009 Mac Pro, 32Gb RAM
Old 03-18-2018, 03:14 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Most EDLs are written with basic text characters. So you should be able to just drop the EDL file onto the TextEdit app icon in the dock. Some old Sony EDL formats aren't so you'd need a specialised app to open it like Avid media composer.
If you want to do something more than just read the EDL in TextEdit you can use an app like EdiLoad (which I created) to create markers or clips at the picture edit points, create a PT track containing clips where scenes start and end, or use it to compare picture EDLs to cut your session for picture changes.
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
HTML code is On
can HD8 license open HD7 software? sound_music Pro Tools TDM Systems (Mac) 3 04-17-2013 07:31 AM
Software Updater crashes on open wesm macOS 2 10-20-2012 09:41 PM
Making a PT session open in other software (DP4)? cedar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-13-2006 12:52 PM
6.9 software won't open odd-e-o Pro Tools TDM Systems (Win) 5 05-22-2005 12:02 PM
