Old 03-10-2018, 03:04 PM
chrismeraz chrismeraz is offline
Default Delay Compensation for Harware Inserts
I've had to turn OFF delay compensation in order to get my hardware insert (dbx 160A) to return a signal that is in time with the music. Is this normal? If I turn delay compensation ON, the return signal is ahead of the rest of the music.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 03-11-2018, 02:29 PM
K Roche's Avatar
K Roche K Roche is online now
Default Re: Delay Compensation for Harware Inserts
Humm? I have not found that to be case on my system I have two HW units set up as inserts However both are on Aux input tracks ..... An analog HW comp on the "2 Mix" bus (main bus Aux track) , and Digital reverb its own Aux track.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 03-11-2018, 02:41 PM
BScout BScout is offline
Sounds like your audio interface (Apollo) is over-reporting its buffer/delay so Pro Tools is over-compensating. This is a problem with your audio interface drivers so it is going to be specific to what audio interface you use.
Do you have any UAD plugins running in your Apollo mixer (even bypassed/inactive)? Try removing all your Apollo drivers, clear any UAD Apollo preferences/settings, and reinstall the Apollo drivers. (No need to remove the UAD plugins -- just trying to reset the communication with the Apollo and reset the Apollo mixer)
Old 03-11-2018, 02:51 PM
Thanks guys. Well I don't know what was wrong, but it's working today with Delay Compensation on and the audio is well-aligned, as it should be!
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 03-12-2018, 11:13 AM
K Roche's Avatar
Hey great
System :
Enjoy the Journey
.... Kev...
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 03:35 PM
hardware inserts and delay compensation PT8 PointStudios macOS 0 10-09-2014 04:23 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation with hardware inserts d.f. Pro Tools TDM Systems (Mac) 18 03-10-2009 11:57 PM
DELAY COMPENSATION ON INSERTS WrekdaHouse.ar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-27-2005 11:22 AM
