Old 04-06-2002, 09:31 AM
blanos112 blanos112 is offline
Default PT versions compatibility
Can someone please make clear what versions of protools are compatible?eg can u open a 5.2 session using 5.1.1?
thanks
Old 04-06-2002, 03:05 PM
Alex Rodriguez Alex Rodriguez is offline
Default Re: PT versions compatibility
Iīve been able to open old versions on a new PT one. Thatīs logical, of course. Once I received a PT session (I never new which version was) on a TDM 5.0.1 and I couldnīt open it. I assumed it was 5.1, but the client couldnīt tell me. The PT Open dialog couldnīt see it, although there was an PT icon on the Mac. I had to use the original time stamp option to go on with the recording session.
Alex
MacBook Pro 2.16 GHz Intel Core Duo, 2 GB of RAM, OS 10.4.11, PT 7.3.1
Old 04-08-2002, 09:28 AM
DigiTechSupt's Avatar
Later versions of Pro Tools are always downward compatible with earlier session formats. For instance, Pro Tools 5.1 can open PT 3.2, PT 4 and PT 5 session formats.
PT sessions created in 5.1, 5.1.1, 5.1.3 or 5.2 all use the same session format and are all compatible with one another.
Brent
Avid Audio Tech Support
Support FAQ
Old 04-09-2002, 06:50 AM
In addition:
-Here is some good information regarding PT TDM 5.1.3 and 5.2 compatibility:
http://www.digidesign.com/compato/513.html
-There are problems opening sessions created on PT LE 5.2 (MBox) with a Mix system...PT LE 5.2.1 resolves this incompatibility:
http://www.digipronet.com/ind ex.cfm?page=digistudios/521_bugfixes
Brent
Brent
Support FAQ
Different card versions according to PT versions? ambidextrous.PR Pro Tools TDM Systems (Mac) 3 12-21-2013 03:08 AM
Mac Versions compatibility dedalus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-29-2011 07:06 AM
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 11:05 AM
McDSP: Compatibility across PT versions RenderBot Post - Surround - Video 7 07-19-2006 10:41 AM
session compatibility between versions AND platforms Craig5024 Tips & Tricks 1 07-22-2003 01:12 PM
