Old 03-27-2001, 09:17 PM
Reemabeets Reemabeets is offline
Default I get stuck midi notes in 5.1 when i click outside of protools LE
i get stuck midi notes when i click outside of protools window. i never had this problem in 5.0.1 because i used the DIGI BACKGROUND MIDI INT in my extention folder & it worked in 5.0.1 but do not work in 5.1 i have a mac G4 please help if you thanks
Old 03-28-2001, 10:29 AM
vvh vvh is offline
Default Re: I get stuck midi notes in 5.1 when i click outside of protools LE
I get stuck notes or no notes at all when switching between apps. I have posted this before as well. Digi, please help.
vvh
Old 03-29-2001, 07:17 AM
DigiTechSupt's Avatar
-I cannot reproduce this behavior (Pro Tools is playing a MIDI sequence as I type this message).
-What kind of MIDI interface are you using (Serial or USB)?
-Make sure that "Run MIDI In Background" is enabled in the Setups>OMS MIDI Setup window.
-Disable "Use Apple Serial DMA When Available" in the Edit>Preferences window of OMS
Brent
Avid Audio Tech Support
Support FAQ
Old 03-29-2001, 06:42 PM
vvh vvh is offline
I am only running virtual synths (QuickTime and Koblo). This happens on a regular basis. When I click to switch to another app, the MIDI often stops, or gets stuck on a note. I will check the settings you have suggested.
vvh
Click/counter stuck on 8th notes dankin macOS 1 09-25-2012 03:15 PM
Stuck midi notes NinjaBob MIDI 2 08-28-2007 10:13 AM
Stuck MIDI Notes! delgadil MIDI 1 08-07-2007 03:39 PM
Stuck MIDI notes in 6.9.1 CraigLearmont MIDI 1 03-05-2006 04:07 PM
ProTools 6.4 - INTERMITTANT STUCK NOTES!!! liquitrax Pro Tools TDM Systems (Mac) 0 06-04-2004 05:14 PM
