Old 12-06-2015, 01:30 AM
Beau_McKee Beau_McKee is offline
Default Half way through LP mix -Panning settings not matching audio pan PT12HD. Please Help
When i open up my session and check my panning i notice that protools is not matching the panning that i have set on the track or have automated. This is happening with tracks that have automation. For example 100% right panned will be playing somewhere near the center (for example) or will come out with some messed up balance that is not what has been automated or set to. When i adjust the settings it seems to register correctly again for 30 seconds or so and then starts messing up. Never had this error in the 10+ years of a being a pro tooler. Im trying to bump this record out for a deadline next week, any help would be appreciated. This is definitely an error of sorts, not some silly routing or other obvious user error. I have tried restarting the session numerous times and not getting any good results with same erratic panning issue on some tracks.
Specs:
Hackintosh 4770k
OSX 10.8.5
Profire 2626
Pro Tools 12.3.1 HD
32GB DDR3 Ram
Let me know if you need any more info. Your time is much appreciated, especially if i can figure this one out!
Old 12-06-2015, 04:57 AM
joachim's Avatar
joachim joachim is offline
Default Re: Half way through LP mix -Panning settings not matching audio pan PT12HD. Please H
There can be a bug with wrong pan automation, when the track is set to ticks.
A "reset" : set the track to samples and back to ticks. Resolved the problem in same instances.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-06-2015, 08:34 AM
Great, i will try this today. Thankyou very much
Old 02-23-2016, 06:37 PM
jb_thirdion jb_thirdion is offline
Thanks joachim!! This has been plaguing me for a while. How did you figure this out?? Thanks again!
Installing PT12HD from PT11..Need to ensure my saved Plugin settings don't get erased rcd Pro Tools 12 0 06-03-2015 12:53 PM
Did 8.0.5 Fix the Latency and Panning Settings Issues? numberforty1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-07-2011 12:29 PM
If You Change I/O, PT Will Delete Panning Settings - Watch Out!! numberforty1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-30-2010 07:01 AM
Why is PT8 Deleting my Panning Settings?!! numberforty1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-29-2010 07:06 PM
The Matching Criteria List and Matching Playlists EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-13-2009 01:35 PM
