Old 05-06-2011, 07:07 AM
montreal montreal is offline
Default recording at half speed...
hey guys, noob's leader here..
i want to record an audio file at half speed in protools...
i know that its possible thrue CMD+shift+space bar but my question is how do i have to set my tracks ?
i mean, lets say the audio file is on track 1. i want to record the audio file at half speed in pro tools on lets say track 2.
what am supposed to do on the output/input etc to make that working ? coz i tried and the only thing im recording is silence ....?
Old 05-06-2011, 08:07 AM
Default Re: recording at half speed...
someone has an idea ?
Old 05-06-2011, 09:37 AM
How come it appears pretty impossible to obtain an answer on this forum these days ??????????????????
Old 05-06-2011, 10:43 AM
tom1325 tom1325 is offline
Hi, unless I've misunderstood your question, you would just route the tracks as you usually would, so for example
Track 1 output = Bus 1-2 (For example)
Track 2 input = Bus 1-2
I aplogize if this is not what you meant.
Old 05-06-2011, 11:13 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
When u record that way, the audio will be an octave up; so u'd need something like Serato or u could use EA to pitch it correctly...
Sent from EPIC 4G using Tapatalk On'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 05-06-2011, 11:36 AM
Top Jimmy's Avatar
If you play a file at half speed and record it at half speed, you'll end up with an identical copy at the same speed as the original.
If you really want to varispeed, look in the Audiosuite menu for the Time Shift plugin and use it to varispeed down 12 semitones.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 05-06-2011, 08:02 PM
And as said above, no special IO setting is needed.
Old 05-07-2011, 03:19 AM
Thanx a lot my friend !! it was just what i was looking for
Noob Leader
Old 05-07-2011, 03:22 AM
Thanks a lot !! varispeed is the key for keeping quality... i was using polyphony like a the real noob leader i am... and result was [bleep][bleep][bleep][bleep]... now its just perfect
Half Speed Recording layres Tips & Tricks 1 03-02-2010 12:07 PM
Recording at Half Speed. SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-14-2005 07:44 PM
recording at half speed SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-01-2005 01:38 PM
half speed recording murr Tips & Tricks 2 11-18-2004 01:46 AM
Half-Speed Recording mdimmm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-15-2004 05:09 PM
