Old 10-23-2008, 01:59 PM
soundsinamotion soundsinamotion is offline
Default Quicktime import aspect ratio wrong, help!
I'm using my protools le 003 rack and just imported hd video into the session. the original aspect size is 1440 x 1080. When I import the quicktime .mov into a protools session the video gets squeezed and it's not a widescreen anymore. How can I get protools to import the exact ratio of this .mov? it plays perfectly with the quicktime player.
Old 10-23-2008, 04:09 PM
Slim Shady Slim Shady is offline
Default Re: Quicktime import aspect ratio wrong, help!
This is just a guess... but is it maybe anamorphic? With the movie open in Quicktime player, do a "Get Info" (command-I) and check the "Normal Size" vs. "Current Size" at the bottom of the info window that pops up. Those should match, if not it's using an anamorphic aspect ratio, and you'll have to export it/copy the movie with a fixed aspect ratio in order to fix that.
Old 10-23-2008, 07:28 PM
hmmm i'm not sure what you mean by anamorphic. There is only one resolution size which is 1440 x 1080 when you get the info on it. I would think protools would be advanced enough to be able to import any size?
Old 10-24-2008, 09:59 AM
DigiTechSupt's Avatar
If you open the video in Quicktime and go to Window>Show Movie Inspector - what does it show for Format and FPS?
Avid Audio Tech Support
Support FAQ
S3L Aspect Ratio Jason Raboin VENUE Live Sound Systems 1 09-27-2013 10:38 AM
Quicktime DV aspect ratio and PT9 Vytis Post - Surround - Video 4 01-23-2011 05:11 PM
Why is bounce to quicktime changing aspect ratio? efisch Post - Surround - Video 3 07-22-2010 08:57 AM
Video Import Aspect Ratio Madness postmike Pro Tools TDM Systems (Mac) 9 04-23-2010 08:20 AM
Video Import Aspect Ratio Madness postmike Post - Surround - Video 1 03-30-2010 12:44 PM
