Old 11-08-2004, 04:17 PM
TuT TuT is offline
Default Bypsss buttons not working in 6.41
Hi all,
I am using (with mixed success) Protools 6.41 on a Mix TDM system.
My 'lastest' bug is this:
50% of the time the bypass buttons on plugins don't work. They always look to be unbypassed (plugin on). When I press the button nothing seems to happen BUT you can hear that the plugin IS being bypassed.
So the button is changing the audio, but the screen doesn't show any change. Seems like another graphics bug.
This error occurs mostly when I copy a plugin from one inset slot to another. If I disable the plugin, then re-enable this usually fixes the problem. But having to do this all day is very tiresome. The fault is happening on all plugins.
I have removed all but the digi plugins, plus about 4 others, to see if the problem goes away. No luck. I will try removing all but the Digi plugins next but I'm not hopeful.
Protools Mix 3 / 6.41 cs1
UAD-1 card with latest software plus latest VST-RTAS adapter
OSX 10.34
Apple dual G4 1.25GHz MDD
Mbox Pro some front panel buttons not working! azah FireWire and USB Audio Interfaces (Win) 1 07-29-2015 03:33 AM
PT10 - transport buttons not working Led Artist Series 2 06-20-2013 02:35 PM
No Record buttons working since d/l 9.06 Tedly macOS 0 12-10-2011 12:28 PM
MBOX Pro Buttons Not Working BOSSHOG Pro Tools M-Powered (Win) 0 11-15-2011 11:13 AM
Group buttons just stop working uno1234 ProControl, Control|24, Command|8 5 03-09-2005 09:23 AM
