Old 06-03-2014, 12:18 PM
mike_mccue mike_mccue is offline
Default Can I import a "track template" into an existing session?
Let's say I have a template saved in the system that is dedicated to a mic'd up drum kit. It's got 7 tracks, a bunch of inserts, and a "drum" bus.
Is there a way to import that info into another session that has for example, 2 existing tracks such as vocals and acoustic guitar, a reverb bus, and a Master Fader?
In my previous DAW this was a simple a "load track template".
What is a good way to do this sort of stuff in Pro Tools?
Thanks.
Old 06-03-2014, 12:29 PM
Craig F Craig F is offline
Default Re: Can I import a "track template" into an existing session?
"Import Session Data" to new tracks
Thank you,
Craig
Old 06-03-2014, 12:35 PM
JFreak JFreak is online now
If you have PT11, here's what you could try:
1) create a session where you have that drum kit set up as you wish. nothing more, just the drum kit tracks and routings and plugins. no master faders, no extras, just what you need.
2) save that ptx to your desktop and rename it into whatever.ptxt
3) check what is your PT root folder. mine is /Users/Shared/Pro Tools
4) find that folder and create a subfolder called "Track Presets"
5) in the track presets folder, create a subfolder called "Drums"
6) move that whatever.ptxt session file to that drums subfolder
7) open your existing session and create a new track
8) in the new track dialog, open the "audio track" dropdown menu and you should see "Drums" there.
9) Just select your whatever preset you just created
10) PT11 should have added the tracks which you created in step #1
Old 06-03-2014, 12:36 PM
Thanks Craig,
I was reading the help files on that before I asked here but just couldn't figure it out and thought maybe I was expecting it to do something it didn't do.
I'll go back and read it again.
Thank You!
Old 06-03-2014, 12:37 PM
Thanks jfreak!
Old 06-03-2014, 12:42 PM
Remember, this is unsupported procedure but should work...
"Create Session from Template" --> not showing CR92 Pro Tools 11 0 12-24-2013 06:05 PM
"Import Session Data" Audio File Duplicates acstctws Pro Tools 10 1 03-01-2013 03:06 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Pro Tools LE and "Import Session Data"? lydpik Tips & Tricks 5 09-11-2009 05:12 PM
"Import Session Data" tempo issues GJV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-08-2009 05:57 AM
