Old 05-26-2023, 08:25 PM
acoonrad acoonrad is offline
Default Delay Compensation Amount Error
Hey there, using the new apple silicon protools build 2023.3 with apple silicon UAD on a Mac Studio running the latest Ventura (13.4). Stoked on this new machine, running very fast and smooth.
In the past, pro tools delay compensation has worked fine automatically with Apollo when using hardware inserts but with this new setup, delay compensation is working (showing in mix view and delaying a certain number of samples) BUT there is an audible phase issue.
Test case
: When I have two identical audio tracks playing at the same time to the same output, one with hardware insert and one without, there is an audible phase issue indicating incorrect amount of delay, even though the insert does trigger delay compensation on the track. I’m testing this with just a direct patch cable from output to input. No outboard.
I have the channel muted in console etc, I’ve troubleshooted all the basic stuff. can’t figure out what might be causing this.
Buffer is 512, 48K sample, Burl bomber as clock. I’ve tried different buffers and input delay in console as well as a couple of other things, all yield different flavors of phase issues.
Any ideas where to look? How do I ensure PT is delaying the proper amount for my interface and settings? Thanks!
PS This is my first time using PT with native silicon support and its definitely faster. Everything seems to be super stable even with large and complex sessions. Only issue is this delay comp problem.
PROTOOLS 2018.3 Bounce delay compensation ERROR with UAD v9.5.1 AUX insert modulo2008 Pro Tools 2018 7 05-30-2018 02:10 AM
Parallel Compression - Delay Compensation Error? tim_mop1 Pro Tools 11 8 09-23-2016 02:59 AM
Delay Compensation Access Violation Error Fuzzyc Pro Tools 11 2 01-18-2015 05:50 AM
Delay Compensation error (Bug?) PT7.4 Redbeard Pro Tools TDM Systems (Mac) 3 03-11-2008 10:18 AM
Plugin delay amount Dfazio Pro Tools TDM Systems (Mac) 0 05-31-2007 08:59 PM
